Question about Toys
My gemmy brand light show christmas tree not working........
Worked for one day and then stopped???
don't know why.
weather did not cause this.
everything is plugged in right and nothing broken.
on www.gemmy.com does not show details of how to fix. has nothing to do with broken products.
i have a problem with my gemmy single tree lightshow.
I NEED HELP!!!!!
  • 8 more comments
  • C-Horse Dec 16, 2008
    I have the exact problem. Used it last year, worked great. Set it up this year and worked for one day then quit. All is plugged in correctly, power supply is outputting 25V AC. The controller does not have an internal fuse. When the button on the controller is pressed, the light flashes red. I'm assuming this is an error (I don't have the instructions).
  • sldl1 Dec 21, 2008
    tree are not working
  • ron1142 Dec 22, 2008
    i have same problem will not turn on.. every thing is like it supposed to
  • Anonymous Jan 01, 2009
    What reset button
    I bought my Gemmy Tree Light Show this year and it worked for two days then quit. It does nothing when I press the reset button. The black activator (power) box makes a humming sound when its plugged in.
  • jmay15 Jan 19, 2009
    It stopped working a week after we bought it and we don't know why
  • fandaanx
    fandaanx Dec 06, 2012
    I tried all the suggestions listed to no avail. However, after an hour of trying I finally came up with a solution.1gal of gas, 1 match and walla light show, worked great for about a half. Sadly the fire-department and cops did not appreciate my light show. =(
  • fandaanx
  • Tommy Long
    Tommy Long Dec 08, 2012
    I have the smae thing i used last year i put it out these and worked for a while and quit i think the box you have to plug in to . Wander where you could get one of them ?
  • John Walls
    John Walls Nov 19, 2016
    2 reset buttons. One on the large tree if you have the 3 tree or just look at the back of the main control box, push that and take a toothpick and put it in hole above battery cover should hear slight click. That should reset whole system. Worked for me.
    Problem Solver:
  • 8 Answers
When you press the reset button on the controller box, then you need to press the small recessed button on the back of the remote control. You'll need a pen to get in there, or better yet a paper clip. That will reset the remote.
Posted on Dec 18, 2008
  • Alanda Hollins Dec 13, 2012
    Thank you.......I was approaching major frustration! Oh and btw.....turn the remote off, reset and then ta-da!!
WHERE IS THE INTERNAL FUSE LOCATED I TOOK OFF THE MAIN BOX WHERE EVERYTHING FEEDS IN AND I DONT SEE THE FUSE
Posted on Nov 29, 2009
There is a fuse located on the bottom of the main box. Unscrew the cap and remove the 8 amp. fuse. go to your near by hardware store and buy a replacement. Put iit back in and wa la. it should work again........ it happened to me
Posted on Nov 25, 2009
  • Marie Dixson
    Marie Dixson Dec 05, 2015
    What is the main box ?is it the power black box or the box with the reset button on it please help
The reset button worked like a charm!!! Thanks so much!!
Posted on Dec 06, 2012
I tried all the suggestions, starting with tapping the prongs with a key, then resetting the remote and tree together, finally trying the fuse. I took the box off and didn't see what would have been a replaceable fuse so I made sure the wires had a snug fit. While the box was opened I reset the remote and tree again and alas my tree is on.... now all I need is to move it back outside to try it out after moving it! Good luck to all of you I know its frustrating!
Posted on Dec 05, 2009
Reset button on the back of the remote brought music to my ears!
Posted on Dec 24, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
If your unit has the problem of working for about a minute, here is how I fixed it.
Open the tree with all the wires. Follow the 24vac line to the power board. Between this input and the diodes (rectifier) you should find a thermistor (looks like capacitor and may be labeled as a fuse). This component is the problem for lots of people. It is designed to limit overcurrent, but I found it is stopping normal function. I fixed this in 2 steps. First, I installed an in line fuse holder on the 24vac line and used a 1 amp fuse. This substitutes for the thermistor protection. Then I replaced the thermistor with a 5 ohm 3 watt resistor. This part is necessary to provide the resistance and current limiting that had been with the thermistor. My unit is working fine now.
Posted on Feb 08, 2017
MY 3 PIECE GEMMY CHRISTMAS TREES STOPPED WORKING THE SPEAKER FOR MUSIC JUST KINDA HUMMS AND THE LIGHTS WILL NOT WORK
Here's what you do... This is for the trio christmas tree light show.
What you need.... small precision pointing tool.
On the largest tree base electrical box there is a push button. Press and release that button. A red led will flash indicating the box is in sync mode. turn the remote on and on the back of your remort, there is a small hole with the words reset over the top of it. Using the small precision pointing tool, press the recessed button and release. The remote will sync to the base unit. Walla!! Merry Christmas to all!!!
Nov 29, 2009 | Gemmy Toys
We bought the Gemmy Christmas tree trio last year. Just set it up today and the light show effects will not reset. Can't find the instruction manual
Press reset on the top of the main unit under the middle tree. The light will blink. While it's blinking, use a pin to press in the reset button on the back of the remote. The blinking light should go out, and you should be good to go. FWIW - I just looked for almost an hour before I found this answer today on-line. It worked for us.
Nov 27, 2009 | Gemmy Toys
Gemmy light show lollipops not working right
The gemmy light shows are amazing when working correctly. BUT that may be for one season only. I bought the white trio set of Christmas trees after one season the trees turned brown, tried to get in touch gemmy. Two days later my reply was I improperly stored my trees. All the other set of trees I've seen turn brown after one season. As far as I know gemmy quit making the white trees. Long story short they did't warranty my trees, as for the lollipops 4 or 5 light systems aren't interchangeable, I tried to replace the led in my 5 light system with a led from a 4 light system the led worked but wouldn't sync. When trying to make repairs you must use parts from alike sets of the same year models, alike models from different years don't work. Also when changing led circuit boards solder the wires the way you take them off or you'll short the board out. If you have bad sets of lights you can make repairs if they are alike.
Nov 18, 2008 | Sport & Outdoor - Others
Toys Logo
5,077 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
