SOURCE: hi there just brought a
Hello
Since this is covered under warranty do NOT attempt any repairs, if you tamper with the engine in any way you will void the warranty. Return it to the company that sold it to you for repair. Based on what you say you most likely have a fuel delivery problem, it is to rich, that means the engine is getting to much fuel, this causes the engine to flood out, the other possibility is the engine has poor compression.
SOURCE: 49cc mini pocket quad wont start
if it has a kill switch make sure it is on, check that you are getting spark at the plug and have the right fuel in the motor.
Remove the air filter from the carbi and squirt some 2 stroke fuel directly into the throat of the carbi and try to start it.
hope this helps
