Question about Sunpak (SDPF-070AW-0US) Digital Picture Frame
Can't load photos on to the Sunpak digital photo frame
I can't get the photos loaded onto the Sunpak photo frame. I have checked the files and they are all JPEG picture files on my SD card. Am I doing something wrong?
  • ricky rabbit Dec 17, 2008
    I have the same problem BUT I have a bad fix. I took pictures of the pictures on a reformated disk in my Canon 620A camera. Now I can put this SD card in the Sunpak and the pictures are there.
    If you put that SD card in your computer and add a picture that you downloaded from the same camera it will NOT work in the Sunpak.
    Rick
  • foto_lover Dec 21, 2008
    I saved a bunch of .jpg files onto a new SD card, and the Sunpak just says "Loading." I then took the SD card straight out of my Nikon and into the frame, and it does the same thing. "Loading" is all I get... Help!
3 Suggested Answers
  • 5 Answers
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Posted on Dec 20, 2008
SOURCE: just bought a sunpak 7"
I have found that when you have the source of the photo files connected to the picture frame and are viewing from the menu it says "USB" Select the photos you what to paste by following the instructions and then change the "Device" to "favorites" and the paste by pressing the "enter" button.You can only paste about 10 files or photos at a time...so if you have allot it take a while. hope this helps
Posted on Dec 21, 2008
smartr10U
  • 1305 Answers
SOURCE: I need a downloadable user guide for 7
You can get your manual by Clicking HERE
Posted on Dec 09, 2009
How to load photos onto frame
transfer the image from PC to memory card ( JPEG Format) and then insert the card in the photo frame. Then turn on and play.
Oct 05, 2012 | Kodak EasyShare SV811 (8858946) Digital...
Have a new 8 gig memory. Shows full before all pictures load, should have loads of room?
I would format it using your computer, then try loading in your photos again.
In Window, go to your file explorer, right click on the drive and click Format.
http://www.blogsdna.com/wp-content/uploads/2009/01/format-usb-drive.png
It's ok to do a 'quick format'.
This will delete everything on the drive.
Now try loading on your photos, and see if that made a difference.
Mar 07, 2011 | Philips 7FF2CMI/00 Digital Photo Frame
I have a SunPak SDPF-o8o-OSL frame. When I turned it on today instead of the photos I was expecting, I got a screen filled about 75% with colored vertical lines.0 (It looked sort of llike...
You may have mistakenly started in test mode, I suggest resetting the device, here is a link to the manual, it should have something about resetting the frame.
http://www.retrevo.com/support/Sunpak-SDPF-080-Digital-Photo-Frames-manual/id/23157bh642/t/2/
Feb 28, 2011 | ToCAD America Sunpak Digital photo frame ...
Customer service to help me to use quantaray by sunpak
I have a quantaray 15" photo frame and I cannot get the screen bright enuf to see the image.
Dec 31, 2008 | Quantaray 7-Inch Digital Picture Frame -...
I have a Quantaray 7" digital photo frame by Sunpak. I am unable to adjust the brightness. It stays dark all the time. It was the last one Wolf had and the direction where missing from the box. The screen...
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Dec 25, 2008 | Quantaray 7-Inch Digital Picture Frame -...
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
I am not able to put the pictures on the internal memory?
Had this same problem and found this solution after digging on this forum, and it worked...you have to pay attention to the "Device" you are pasting to. It's cumbersome for copying mutliple pictures, but with persistance, it works.
"I have found that when you have the source of the photo files connected to the picture frame and are viewing from the menu it says "USB" Select the photos you what to paste by following the instructions and then change the "Device" to "favorites" and the paste by pressing the "enter" button.You can only paste about 10 files or photos at a time...so if you have allot it take a while. hope this helps"
Dec 17, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Just bought a sunpak 7" photo frame. Trying to put pictures from flash drive onto the memory on frame. How do i do it?
Dec 03, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Sunpak (SDPF-070AW-0US) Digital Picture Frame Logo
147 people viewed this question
Top Sunpak Photography Experts
Tony
Jazz Boyce
Jazz Boyce
Level 1 Expert
Jay Plesset
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
