Question about Gateway MX6428 Notebook
Hinges Broken I've had Gateway repair the left hinge twice and the right hinge once on my notebook. Now the warranty is over and both are busted. what's the typical cost for a repair like this.
  • 408 Answers
Go to EBAY or wherever and get the hinges and replace them yourself.Its fairly simple, mostly requiring a small 4way screwdriver and taking your time doing it.A repair shop will probably charge too much for such a simple repair.Before replacing them try to put a little silicon lubricant on them as to prevent future breakage.Also when you open your laptop always lift the screen in the middle or lifting from both sides keeping stress off the hinges.
Posted on Jul 28, 2009
Gateway M-7315U hinge
Check out this WEB site - Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
Nov 06, 2012 | Gateway M-7315U Notebook
The right and left - hand hinges of my Asus notebook got damaged. Where can I have them repaired? Only those parts got broken a little bit, just like semi-fructures. Thanks.
Hi, Just go to ur nearest computer shop and ask them to replace that hinge! the hinge becoming stuck and only solution would be to replace it! The crack can be repaired and repainted if there is no available parts in the market. Ur concern should be the hinges, replace it before it breaks the whole hinge holder!
Jun 14, 2011 | ASUS Computers & Internet
The door hinges on my 3210 have broken. can i get replacement hinges
hinges seprately cannot be replaced . for support needs you can call hp tech support team 1800-474-6836 ask for printers and ask for the same. if its under factory warranty the entire printer can be replaced//
May 07, 2010 | HP Photosmart 3210 Printer
Lcd hinges cracked
The parts you're looking for are called "display panel hinges" You can buy these parts from compaq/hp directly, but personally, I would call, find out the part number and try to find a cheaper place to purchase them. A detailed video on removing the LCD panel completely can be found here. This will show you how to remove the broken hinges, and on the left side of the page, you can select videos that will show you how to do practically everything else. To get your replacement parts go to the compaq website (I couldn't find the part without the serial) or call 1-800-227-8164. There is also a live chat option once you go to the support section of the website. You may be able to rig the display so it works without buying a part, but now that you have the information, it's up to you. I hope this helps!
Jul 14, 2009 | HP Compaq Presario V5201us Notebook
Hinges Broken
From my experience working with Gateway repairs in a service center, average price on hinge kits are usually around the $125USD mark, if you do it yourself. Of course if you were to bring the unit to an authorized service center to have a technician repair it then there is labour charges on top of that (which will be variable from shop to shop). A better resource to look at directly though would be here, you can probably get some cheaper prices on parts for this model of notebook.
May 29, 2009 | Gateway MX6428 Notebook
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
Broken Lcd hinges
No,you can't fix the hinges if they become slack, you wll have to replace the hinges,it's not too difficult on the E500.
Jan 21, 2009 | Compaq Armada E500 Notebook
Broken nintendo ds lite hinge. Do I send it away for repairs or get a new console?
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Dec 15, 2008 | Nintendo DS Lite Console
Gateway 200arc broken hinges
Solution #1 is not accurate. You can find a good number of replacement hinges on Ebay for around $40. The repair is not difficult and can be done yourself :)
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=gateway+200arc+hinges&_sacat=See-All-Categories
Dec 15, 2008 | Gateway 200 ARC Notebook
Replacing the whole monitor screen and bezel
Usually there is a plastic cover that snaps off right about the keyboard that covers the hinges. It is sometimes screwed from the bottom of the notebook thought. Once that is removed you should have a clearer view of what needs to be done. Sometimes there is a few screws from the bottom or back of the system that hold the hinges and sometimes the screws are on top of the hinges. You should also see all the cables that go from the screen to the system, unplug those. Hopefully that is all you need to do, but sometimes you have to remove the keyboard and palmrest to get the screen off. Good Luck!
Jan 10, 2008 | Gateway MX6448 Notebook
Gateway MX6428 Notebook Logo
180 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
