Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Time on my Nikon D40 is incorrect.
My D40 time shows to be approximately 37 minutes off. So this couldn't be Daylight Savings time etc. I checked the Date/Time settings and they are correct. All else works fine. Last night at 7:10 p.m. the time on the camera said 7:37.
  • 23 Answers
Being that they changed when the daylight savings time happens everything doesn't adjust the new time accordingly. Go to your menu and scroll to the setup menu. Scroll down to world time and click ok. If you scroll down to date and click ok you can change the time there. Press up or down to change the date and/or time and right and lift to move to the next box. Hope this helps.
Posted on Dec 17, 2008
The time show late every single day..every day i must turn the right time..
Do you have your DVR set for automatic clock updates? I changed mine to manual clock settings because of problems with the new dates for Daylight Savings Time. Every few months I have to adjust the time by a minute or so if I find I am missing the intro to programs that I record. I also have to do the Daylight Savings Time shifts each fall and spring.
Nov 21, 2009 | Panasonic DMR-E55 DVD Recorder
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
I have a nikon d40 and just noticed that time time on it is off by approx. 37 minutes. How can I fix this...
open your menu. Scroll to setting menu. Scroll down to world time and click ok. Go down to date and click ok again. right and left on the arrow pad move between boxes and up and down on the arrow pad changes the date and time (seperatly of course). Hope this help.
Dec 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Incorrect time
go to - preferences / Localize / Time / Time Zone and make sure you have the correct time zone selected.
Also check your daylight savings settings.
Mar 22, 2008 | Navman F20 GPS Receiver
Appointments synching in wrong time zone
Is the incorrect time on the computer you are syncing to then?
Dec 21, 2007 | Palm Treo 755p Smartphone
Calender
I think it has to do the daylight savings time. Try turning off he auto correct on the iphone under settings
Jul 24, 2007 | Apple iPhone Smartphone
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
831 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
