Question about Kenmore 63942 Dryer
Where do I find the make and model on my kenmore?
What should it look like? its a front loader, came with the house.. no manual was left from prior owner.. possibly purchased in 1994 when the house was purchased . This site required that I enter a specific Kenmore.. but I dont know
    President:
  • 2,692 Answers
The data plate is usually located inside the drier door.
Posted on Dec 19, 2008
My fabric dispenser is filling up with water when it has emptied the fabric softner. Is there a way to remove the drawer?
Depends on what model often the Kenmore or Frigidaire who makes most of the kenmore front loaders have a little tab in the upper left hand corner that you can depress to slowly pull out the draw. I looked at the owner's manual it says this is normal.
Sep 05, 2014 | Washing Machines
I have a model 417-44042400 front loader. I
See the following site for Sears manuals for your washer:
They are PDF files that can be downloaded and printed.
http://www.managemylife.com/mmh/owner_manuals/search?query=417.44042400
Apr 05, 2010 | Kenmore 44042 Front Load Washer
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
I am house sitting and i dont know how to use the washer and i cant find the manual with the instructions
If this is a Kenmore Elite front loader as you have this question listed under, you can find a FREE copy of the owner's manual at managemyhome.com. Just locate the model number (listed on a nameplate around the door opening) and enter it under the "Manuals" link. You can view online or download a copy. I hope this helps you.
Sep 05, 2009 | Kenmore Elite 45986 Front Load Washer
Have a intermittent leak in the soap dispensing area in top left area above the front loader sears kenmore # 417.29052991. looking for service manual to guide me on getting into that area for repairing.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2009 | Kenmore Washing Machines
E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Kenmore front loader Model 48102 will not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 14, 2009 | Kenmore Washing Machines
How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Dec 04, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
How do you open the front cover for Kenmore front loader 110.42926200
Sure thing, under the door is a kick panel, held on by three hex screws,standard uses 1/4 inch and torx uses a 9/32 socket. A slight down tug will loosen the panel and behind that you will see the pump at right front. Just to the left is a round soda can shaped housing with a large turn screw lid attached to the pump. Grab a bucket and some towels, unscrew the lid like a jar of peanut butter slowly to let the water into the bucket. This may require two trips and some getting wert. The trap is attached and easy to clean. Next reach behind a gently shake the black boot joining the tub to the pump for coins and lint. The last item is getting a bright light and inspecting the pump through the small hole right side that can be seen once the trap is removed. Check for debris then put a finger in the hole and check the impeller for disconnection from debris/
Sep 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 63942 Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
