Question about Sony RDR-GX300 DVD Recorder
DvdRDR-GX360 Hello- I have a dvd recorder sony RDR-GX360 but it is showing blocked..I really don´t know what is happen with it but just show in the screen DVD1 and all the functions are unables..The manual says that the dvd has DVD3 by the default and if the command mode has DVD1 or DVD2 it will be unable to operate it...My question is How can I unblock it? there is a reset button ? thanks
  • bigbluetape Feb 03, 2009
    I have same problem but solution above did not work...
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Posted on Dec 20, 2008
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
I have a sony rdr-gx 360 with no remote and tey are very expensive to replace. can i get a universal remote for this?
Many universal remotes will operate (with some limitation) most SONY products including DVD recorders. You can maybe find a universal remote either on eBay, remotes.com website (or similar addresses) or perhaps your local electronics store has them in stock - and those are relatively cheap to buy off the shelf. It would then be a question of figuring out and entering the right code for it to (minimally) control the unit. The best universals are the all-in-one types although a 4-in-1 works just as well. Elaborate function remotes will cost more than the basic ones.
Feb 21, 2011 | Sony RDR-GX360 DVD Recorder
I connected dvd to recorder to tv - I get sound but no picture
It simply means there is an error in the connection of the cable to the television.
first ensure that there is a cable plugged to the video out of the dvd then you trace the wire and connect the other end to the vidoe in of the television.
After doing this, your display will come on, on the television.
Try to use new cables, in order for there not to have been a breakage in the old cable you were trying to use.
Take care
Sep 09, 2010 | Sony RDR-GX360 DVD Recorder
Sony gx360 stuck on dvd1
press and hold enter on remote... then, while holding the button (more than 3 seconds) press and hold down the number 1. after 3-5 seconds, things should return to normal.
Nov 10, 2009 | Sony RDR-GX360 DVD Recorder
Can't record movies on TV with my Sony RDR GX360 DVD Recorder
The movies you are trying to copy are "Copywrite Protected"
Mar 30, 2009 | Televison & Video
Disc tray will not open
I've not found one, no, but I have managed to strip the machine down, get the disc out and rebuild... I guess this is too late for you but it's simple enough if you're still trying.
Mar 04, 2009 | Sony RDR-GXD360 DVD Recorder
Have sony rdr-gx360. no manual to show how to work recorder or format cd.
Try this - You will need remote.
After you have recorded video... (if you eject disk all will be lost)
- Push "Setup"
- Now push "Edit"
On left hand side it should now show "Finalize disk".
I also lost manual and took a few minutes to find.
Dec 25, 2008 | Televison & Video
Sony RDR-GX360 unlock
Region lock is given to kill piracy. Please help to kill piracy.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Dec 20, 2008 | Televison & Video
Sony RDR-GX300 DVD Recorder Logo
393 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
