Question about GE WBSE3120B Top Load Washer
Replacing the water pump
How do I get to the water pum and replace it
  • 85 Answers
Part # wh23x10013 for about $62.00 disconnect electrical power with putty knife release front panel ( 2 clip located between top and front panel) disconnect electical connectors , loosen 2 hose clamps from pump(beware of water) and 2 3/8 screws that hold pump to base.then reverse procedure. pump can be purchaced throuh sears.com or local app. parts dealer
Posted on Dec 14, 2008
2002 ford escape. Over heat in about 5 min .already replace the termostat still over heat, no leaks of coolant not sure if water pump working .any suggestions
You should . Replaced the water pum now u have take it a part again . One way to check do . Return hose. On top if it's soft . It could be it. You also have a coolan cord. Under u dahs boar it's very comment. X those to go bad on those tapes off car. It looks like air codition cord it regulates the tem inside u car.
Jun 23, 2015 | Ford Cars & Trucks
Water leaks from top of coolant bottle
You may be overheating. The water pums have been an issue with these cars (Audi,VW). The impeller breaks and will no longer push water. This can be verified if you remove the thermostat and turn the impeller with your fingers (vehicle off of course). If you're able to turn it replace water pump, thermostat and timing belt.
Jun 08, 2013 | 2002 Audi A4
Starite pump d884hg isn't pumping, what could cause this.?
if motor is running check intake unions see if loose if ok check impeller for clog if ok replace pum
Jul 28, 2012 | Sta Rite Pool & Spa
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
At what mileage should I change the timing belt on a 2004 Mitsubishi Outlander. Thanks Sherry
It is suggested by any mechcanic to perform this maintenace every 80,000 miles if you properbly maintain your vehicle. That mean going by the owners manual suggestions. Also I would highly recomend changing the water pum as well for it runs off this belt and water pumps only last as long as the belt will also. If a new belt is installed without a new water pump it may fail in no time. I seen it happen more than a dozen times in the past ten years
Jan 24, 2010 | 2004 Mitsubishi Outlander
Location of water pump 1991 Grand Caravan
I would suggest that you replace the pump, there could be a problem with your pum thats why its way out of alignment and be sure that there's no problem with your engine pulley
Dec 02, 2008 | 1991 Plymouth Grand Voyager
Bosch WFR 2460 washing machine
the pum should do that but the magnet side may have saturated with water beyond the seal. i recommend replacing the pump.
Mar 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washer does not drain
Possible your drain in the wall is blocked solid; snake it out & pour some water to chk it out
May 07, 2007 | Frigidaire CWS3600AS Top Load Washer
GE WBSE3120B Top Load Washer Logo
79 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
