Question about JVC Sirius KD-G300 CD Player
JVC KD-G300 HOW DO I CHANGE THE TUNING INTERVALS. MINE IS CURRENTLY TUNING TO UNEVEN NUMBERS.eg.91.5 ,91.7, 91.9, 92.1... i want tune to all intervals eg. 91.5, 91.6, 91.7, 91.8, 91.8...etc. please help
  • galos Feb 04, 2008
    uneven numbers
  • newkirk Mar 31, 2008
    i just bought a fm transmitter for my mp3 player and i can't get my radio to tune between 107.9 and 90.3 please help
    Scholar:
  • 135 Answers
Here is a link to the manual: http://books.jvcservice.com/download/718134980/32506.pdf There does not appear to be a way to set tuning to european standards. Is there a particular reason you want to be able to tune those frequencies?
Posted on Mar 12, 2007
Thank you very much for the help been trying to solve this issue for days. The holding AM/FM and #5 works.
Posted on Aug 23, 2007
Hi, thankx for coming back. i'm live South Africa, our tuning is normally set to European standards. I managed to get a way to do it. "Hold FM/AM and Press #5" this resets it to European standards.
Posted on Mar 13, 2007
SOURCE:
My hp elitebook 6930p refuses to power on, screen black and keeps turning on the power light and turning it off again at intervals
The elitebook is trying to tell you via the power indicator etc. what the failure is on starting up.
Read this page to determine what the problem is and what to do about it.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01732674
Feb 14, 2015 | HP EliteBook Computers & Internet
How to tun up
There is not much these days to tuning up a modern car. A lot of things are not adjustable anymore. You should not mess with the idle speed, engine timing, and emissions gear unless there is a problem indicated by the engine check light, or it does not pass the annual check for rod use. It boils down to changing the spark plugs, oil, coolant, etc at regular intervals.
Jun 06, 2014 | 2004 Toyota Avalon
Mitsubishi mirage 1995 50,000maitenance requirements
MAINTENANCE INTERVALS FOR 52500 MILES IS ENGINE OIL AND FILTER CHANGE.TIMING BELT CHANGE IS 60000 MILES INTERVAL. MOST OF ENGINE TUNE UP IS DUE AT 60000 MILES INTERVAL.YOU NEED TO REPLACE TIMING BELT, REPLACE ENGINE COOLANT, REPLACE SPARK PLUGS,REPLACE IGNITION CABLES. REPLACE ENGINE OIL AND FILTER. YOU NEED TO SERVICE AND INSPECT ALL THESE ITEMS, AUTOMATIC TRANSMISSION FLUID AND FILTER,BRAKE HOSES, BRAKE PADS,DRIVE SHAFT BOOTS,VALVE CLEARANCE,BALL JOINTS AND STEERING LINKAGE SEALS,DRIVE BELTS,EXHAUST SYSTEM,FUEL HOSES,MANUAL TRANSAXLE OIL,REAR DRUM BRAKE LININGS AND REAR WHEEL CYLINDERS.
May 21, 2011 | 1995 Mitsubishi Mirage
How do you change your chord set-up on an autoharp and is there any reason not to set it up like a piano keyboard (C-D-E-F-G-A-B)? Thanks in advance.
An autoharp makes chords by muting all the strings except those that make the chord. There would be 2 ways to change the chord structure. 1) retune the strings knowing which ones will be muted by each key so that the result is another but valid chord or 2) make your own "keys" so that they mute different strings.
The tuning of an autoharp is selected to allow you to play songs as long as they are in the right key or two. If you set it "like a piano" as you suggest, you could play those chords but not the chord sequences that make up most songs. Most songs revolve around sequences or intervals such as the popular 1 - 4 - 5 blues progressions. Most music has some predictable progressions and that's why the autoharp is tuned the way it is.
You can always experiment with different and odd tunings but if your goal is to play already written songs, I'd stick with the normal tunings - there are alternates.
Jan 29, 2011 | Oscar Schmidt Autoharp
If I use synthetic in my primary how often should it be changed?
You may want to follow the standard changing intervals just so it is easier. With synthetic oils you will benefit from better lubrication, cooler temperatures, longer transmission life, and if you desire longer intervals between changes. You could just change as needed shorter intervals city driving and much longer intervals highway driving , much like motor oil. Or set a longer interval to follow for the transmission change. The manufacturer usually gives you recommendations in the owners manual , unless you keep a chart it is just easier to follow that recommendation. Besides, oil is cheap compared to your bike. More changes are always better than less changes.
Sep 16, 2010 | 2006 Harley Davidson FLHR Road king
Hello, I have a VW Golf (54 plate) and the radio keeps re-tuning as I'm driving along. It does this at random intervals (sometimes minutes apart, sometimes up to an hour) and changes the frequency by just...
My personal suggestion would be to go for these repair catalogs from www.reliable-store.com instead. much better info on all vehicles, complete details, and they also
have live assistance feature
Mar 04, 2018 | Volkswagen Golf Cars & Trucks
If I am changing from reg oil to synthetic is there anything special I have to do before I put the syntehtic also is it true that you can go longer on sytetic oil than reg oil? Kia Sedona 06
I like to say that sysnthic oil is great but engines that are oil enought to have built up deposits from the ordinary oil these deposits can turn hard and scratch up the motor if the engine is near new or newly rebuilt nothing but pu the oil in and go. if it's older you can get benifits from the blended oils. As for longer change intervals the oil it'self may be OK but engine wear and tuning problems can get contanimants in the oil and the oil will need to be changed to get them out. so the ecomomy of the better oil and longer change intervals willbeovercomed by the added drit so often changs=es with ecomony oil may be cheaper and better. If the oil stays clear for a long time the full sysnthinic and longer change times may be the way to go. The higher price of the full synthic oils and then chnge it less often than the difference in price may be too long and therfore no savings
Mar 22, 2010 | 2006 Kia Sedona
Who sets the "service now" interval?
yes you should go to the dealer for this,you either have a soft code or a hard code.If the light is always on it is a hard code,get it checked before more problems occur.
Jul 24, 2009 | 2007 Volkswagen EOS Convertible
Tuning the JVC radio
Hi, it depends were you got the radio from mine is doing the same its a grey product and comes from US or other countries.If you are lucky just hold and press the setup key for +- 5 seconds and it will jump to setting HH then press the + or - button were you change the radio, go to area and turn knop on radio to US or other country thats working for you. Hope it helps
Nov 11, 2008 | JVC AM FM CD DET FACE CAR STEREO
Sony tv not turning on
I would need the model number to look service codes
Feb 24, 2008 | Televison & Video
JVC Sirius KD-G300 CD Player Logo
542 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
