Question about Ovens
A repairman replaced the RTD
And now @ 350 the temp. reads 300degrees. Can I adjust it to where the temp when set at 350 is somewhere close. by reprograming the control panel, or is there an adjustment in the back.
Thank you
Pat
  • 145 Answers
Hello Pat, it depends which brand and model. Many of them have a simply function where you can adjust up or down by pressing a sequence of keys. If you still have your owner's manual, it should have this info for your model.
Posted on Dec 13, 2008
Why does my oven thermometer read less than the temperature the oven is set at?
An oven doesn't go to the temp selected. That is the average temp. If you set it to 350, it may drop to 300, then to 400, but will maintain an average of 350. Without knowing your model #, it is hard to say. Some have anticipator (that anticipates the temp and controls the heater and the thermocouple that is trying to keep the temp steady. Some models have an adjustment at the oven switch (rear) that can be adjusted for temp up or down.
Oct 20, 2014 | Ovens
My oven is one year old and just past the warranty date by 30 days or so. All of a sudden only the numbers 1 8 9 and 0 will work on the keypad but none of the others This of course means that I can not set...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Oct 01, 2011 | KitchenAid Architect II KEBK101SSS...
Our frigidaire range oven is not able to hold temp...if I set it to 350 it may go as high as 550...but it doesn't always rise that high but it never goes to the temp set or stay at it.
Hi
Daniel
Aug 06, 2011 | Ovens
My Frigidaire FEFL77ABF gets way too hot. When set at 350, temp soars to over 450. Have cleaned oven and tried resetting procedure, but neither worked. High temps are not consistent, so I can't...
Hi
Daniel
Aug 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I get an F3 error code when trying to set the oven temp. Is this problem most likely solved by replacing the temp probe? Many Thanks, Brad
yes F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 24, 2010 | GE Profile JT910SASS Electric Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven temp. is off at times, varies how many degrees
Replace the thermostat, and it should solve your problem.
Please rate my solution.
Thanks.
Nov 09, 2009 | Kenmore Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
My Frigidaire electronic single wall oven FEB275ASB won't stop beeping. It displays a P4 error
F4 Shorted oven sensor (RTD) Check for shorted wiring between EOC and RTD. Check resistance of RTD using resistance table. If resistance test is correct and wiring is good replace EOC TEMPERATURE °F RESISTANCE ω 32 ± 1.9 1000 ± 4.0 75 ± 2.5 1091 ± 5.3 250 ± 4.4 1453 ± 8.9 350 ± 5.4 1654 ± 10.8 450 ± 6.9 1852 ± 13.5 550 ± 8.2 2047 ± 15.8 650 ± 13.6 2237 ± 18.5 900 ± 13.6 2697 ± 24.4
Sep 20, 2009 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
