Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor blinks and then remains blank after computer turns on
Monitor blinks and the remains blank after computer turns on. help!
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    If this monitor is a new replacement for an existing CRT monitor, it is likely that the display refresh rate in windows is just set too high. If that is not the case, and this monitor has worked well in the past, then you likely have some failure within the monitor itself. The later model LCD's with internal power supplies (ac cord plugs into back of monitor) tend to cook capacitors. You didn't indicate whether the display or the power indicator light was what was blinking, you may have a backlight problem.
  • 1,602 Answers
THERE OR AN DEVICE THAT IS CALLED A CHOCK AND IT IS A MAGNET IN A SQAURE HOUSING THE A CORD FITS OVER YOU CAN PICK THEM AT ANY ELECTRONIC STORE THIS MAY HELP WITH AN INPEDANCE PROBLEMS SOME TIMES
CANDYMANGANDY
Posted on Jan 29, 2009
Help me, dish network hd monitor,model 34-310. made in 2004. wont turn on,on button blinks and attempts to,turn on but screen remains blank. tries three times and blinks a green light. no picture,no sound....
It is the right age for failure---IF you are able look inside at the power supply for bad caps---I will attach photos of what to look for.
The three tries is what is called a three strikes and you are out (no joke)----the unit has built into it (many do) a feature where it will try 3 times to make it up and on and if fails shuts down or stops trying.
Dec 07, 2012 | Computers & Internet
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
Monitor don't want to turn on. just blinking. what is the problem?
Sound like the video card is at fault on your PC it sends a signal to wake up the monitor if this is not present then PC may appear to start the monitor will be in standby but remains blank.
Replace your video card even if the BIOS chip says that it is present this will solve you problem
Apr 24, 2010 | Acer P191WBD LCD Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
The montinor is white
Chek the conection on the monitor,open the monitor and chek th conection of the lcd if is conected ok.i had tht problem to,and so i fixed.
Jan 17, 2009 | Hannspree HW191D LCD Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
208 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
