Here's one for the history books!! I replaced the rear bearing since the dryer was making an awful squeaking noise. Unfortunately, I unplugged the washer instead of the dryer before working on it. I actually got zapped when I accidentally touched the element, then for some reason, perhaps I hit the element again, but a few sparks flew and one side of the element glowed orange for several seconds then stopped. I went on and finished the work and fixed the noise problem, but now the dryer is not heating. Is it likely I trashed the element? I guess that's why the manuals say to call a trained professional. Basic safety tip....unplug the appliance before digging into it!!! Anyway, thanks for the help!!
Hello coylejm, Thank goodness, 220v has a BAD reputation. Your hunch is correct. To confirm use a DVM to check the heating elements conductivity. Open one terminal of the element and measure ohms of the terminal. A very unlickley chance you damaged the control box. Merry Christmas.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Harmony DPGT750EC
So I had Sears come out and look and I got an estimate to replace the PWR/PCB ASM-Main and one other...
(More)
So I had Sears come out and look and I got an estimate to replace the PWR/PCB ASM-Main and one other electronic part. Then I found the service code and it says that the "Blower Motor is not getting up to speed. Repair or replace as necessary", if the Inverter was jacked up would I still get the Blower motor message ? I am really confused.
I have ge profile harmony dryer and it runs but will not dry clothes after one cycle. I ran the...
(More)
I have ge profile harmony dryer and it runs but will not dry clothes after one cycle. I ran the trouble check and it points first check inlet thermistor then to blower motor is not getting up to speed. However when I let it sit overnight and ran it this morning had heat and ran which makes me think it is the inlet thermistor. My model is DPGT750EC1PL and it appears to have two thermistor's Any idea of part number for inlet thermistor and then how best to access it to replace it?
I have no heat upon running the unit and there is no exhaust coming out of the vent and all ducts...
(More)
I have no heat upon running the unit and there is no exhaust coming out of the vent and all ducts are clear. Is there an on-board fuse or breaker ?
sometime dryer tumbles without heat---other times it works fine Already checked lint buildup and did...
(More)
sometime dryer tumbles without heat---other times it works fine Already checked lint buildup and did clean duct and outlet at roof That's not the problem Appliance repair person says I need a new blower motor at a cost of nearly $200 Really?
