Question about Honeywell Programmable Thermostat Heater
Want to replace manual thermostat with programmable.
I have a RUUD Seer 10 heat pump. I am not sure want type thermostat to get. I have purchased 2, but they only have 5 wires when my old one has 8.
    Problem Solver:
  • 14 Answers
You can use a 5 wire heat pump thermostat.
Must be heatpump thermostat
red is 24 volt power
white is aux/emergency heat these usually will need to be jumped together
Green is fan
yellow is compressor contactor
blue is reversing valve
you just don't have a common so some thermostats will not work.
get one with batteries
Posted on Jul 27, 2009
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a ruud rcha 36a2g heat pump from 2004. What is the seer rating and tonnage of it? Also inscribed uhbc-17jo6nfh
The unit is a 3 ton or around 36,000 BTU
It also is around a 10 SEER could be a abit more depending on the maych up of the coil and airhandler or furnace combination...
Heatman101
Apr 15, 2010 | Ruud Matching Split Air Conditioner
A/C Compressor Problem 3 Ton
IF the compressor is under warranty they should not charge you anything. it is according to what type of warranty you purchased, If the business is gone, i don't know much of what you can do other than calling ruud directly. Most likely the unit is past the warranty. Call ruud to be sure.
Jul 12, 2009 | Heating & Cooling
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
138 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
