Question about Epson Stylus CX3810 All-In-One InkJet Printer
Epson CX3810 started leaving blank streaks, now no ink on page
I downloaded stamps.com and tried to print postage - it came out with lines of no ink...now when I print I get a totally blank page. I do have plenty of black ink.
  • suecro1 Dec 13, 2008
    Epson tech support explains that the ink jet heads need cleaned. Right click on the printer icon on the bottom right of your screen and follow thru w/the ink head cleaner info. If you need more info, go to epson tech support.
I went to Epson.com's technology on google - and as I followed their prompts, I learned that it was the printer heads and that you aren't supposed to tilt the machine. I have been moving it a lot, so undoubtedly tilted it. You can follow the prompts after a right click on the printer icon on the bottom left corner of the monitor and it cleans the printer head. This also solves a white streak problem if people are having white streaks where there's no pringint....They had lost of answers there too.
Posted on Dec 14, 2008
My Epson Stylus CX3810 will no longer print. Tried going through the cleaning head cycle many times and replacing all ink cartridges. only get a faint partial blue line when I print allignment page.
most nearest problem is that ink head not working may be some ink stock inside and no maintenance for that, you need to replace printer head assembly. practically its better to buy a new one.
Mar 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Epson cx3810 printing blank copies
I had the same problem and had to clean the nozzle tubes. After cleaning the tubes, printer worked great again.
Hope this helps.
Charlene
Mar 11, 2009 | Epson Stylus CX3810 All-In-One InkJet...
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson cx3810 prints blank pages.
Did you remove the seal stickers from the cartridges before putting them into the printer?
Jan 11, 2008 | Epson CX3810 Stylus Color All-In-One...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus  CX3810 All-In-One InkJet Printer Logo
562 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
