I am printing inkjet avery iron on transfers, and i need to print them in mirror image. I can't get my driver to do this. can anyone give me some help, or a patch for my driver or something?
SOURCE: mirror image when I print
Use original cd for driver and repair the driver and if the problem will not be fixed i will be here ;)
SOURCE: brother mfc-440cn
by uesing a special software.
The mfc cant print any mirrow images by itself.
But why do you need to print a mirrow? as far as I remember is the print straight right thru. The foil has to be turned onto the shirt before you run the iron?!!!
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
SOURCE: want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
