Question about Microsoft Xbox 360 Console
System link wont work? we have the xbox 360s connected together and nothings going on
    Problem Solver:
  • 6 Answers
U need a wire
Posted on Dec 14, 2008
I took my xbox 360 slim apart to clean the fan heat sinks etc and put all the connections back into the disc reader and put the whole xbox back together but now the controller will not connect. the...
I havn't had the chance to work on a Slim yet, but from my experience with Phat 360s, you should clean out the connectors for the Ring of Light board with alcohol before reattaching it to the motherboard.
Feb 14, 2014 | Microsoft Xbox 360 Console
Capturing XBOX 360 Gameplay
If you both have Xbox 360s and want to play together, just buy an Xbox Live subscription and play via the Internet. Otherwise, it is impossible to play with him via Skype because your controller would not have an adequate range to connect to his console.
Jun 22, 2013 | Microsoft Xbox 360 Console
My son wants to play against his sister but can't find anywhere that lets her enter the game?
Both have to have xbox 360. Both have to have the ethernet cable attached to each other. (This is called a system link)
  1. Make sure you have the necessary supplies needed for System Linking (all supplies list at the bottom).
    System Link cable or an Ethernet Hub.
  2. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9503394424+9665908481+9016233241+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  3. 2Make sure that all of the Xboxes that will be used are hooked up to different TVs.
    1. 3
    2. To connect two Xboxes, use a System Link Cable and insert one end of the cable into the Ethernet adapter of one of the Xbox consoles and the other end into the other console's Ethernet adapter.
    3. If you are using two Xbox 360s, you can use a standard RJ-45 Ethernet cable instead of the System Link cable.
    1. 4Connect them each into an Ethernet Hub or Switch. A router will also work.
    2. 5Turn each console on and load a copy of the game into each console.
    Oct 27, 2010 | Microsoft Xbox 360 Console
    Cannot get picture just sound when i hook up my xbox elite system
    Double check TV is on video 1,2,3 same for 360s yellow video out.
    If then you still have audio only ,the G.P.U has open connections
    form the video feed to the mother board
    Solution, you must have the G.P.U re-clamp to the main board.
    That Works. 99% of the time.
    Jun 27, 2009 | Microsoft Xbox 360 Elite Console
    Xbox 360 controller wont connect
    Try replacing the batteries. I think you would have tried that but go ahead and try again. If you are new with 360s try to sinc the controller with the 360. Hope that all works.
    dont try tearing your controller apart to try to get it to work. If it doesnt work take it back to the store you got it from and try to get your money back.
    If all of that doesnt work............. buy a new controller.
    May 24, 2009 | Microsoft Xbox 360 Wireless Controller
    How should i fix it?
    You need to contact Microsoft for support. The warranty on an Xbox 360 is three years from the date of purchase. Most 360s are defective, and if that's the case they'll repair or replace it free. The contact information should be on your system or you can find it at xbox.com.
    Jan 01, 2009 | Microsoft Xbox 360 Console
    Xbox shows on computer but xbox says pc not listed
    Had the same problem found but from the start. Had to reinstall windows and check connectivity before installing norton. Then installed norton and it blocked it. just changed firewall settings so ip matched xbox as an allowed sharing device and it worked ok. But it would not do it before i reinstalled windows. a bit extreme but it worked. Now i can read all but my video files after a week of it working fine.lol
    Dec 20, 2008 | Microsoft Xbox 360 Console
    Cant play 2 Xbox 360s online at the same time
    im not sure you can but keep trying and if doesnt work try contacting microsoft
    Nov 28, 2008 | Microsoft Xbox 360 Console
    Xbox live
    Well, you arent supposed to connect them together to play xbox live. You would need to connect them to your wireless network and both of the xbox 360's wouod need to have a wireless adapter. With these ,you could connect to xbox live, or use system link and connect the two.
    Apr 27, 2008 | Microsoft Xbox 360 Console
    XBox 360 2 Red LIGHTS
    found a great repair guide that also has follow along videos. It was an easy fix, and my xbox has been working now for 3 months with this fix. I've also fixed several other XBox 360s using the same guide.
    Now I'm using the guide to buy broken xbox 360s off of ebay and sell them back for big profits.
    You can find this xbox 360 repair guide at:
    3RedLightFix.com
    3RedLightFix.com
    Mar 11, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    44 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
