Question about Philips Business Computers & Internet
Screen blanking my monitor is connected to a Nvidia Quadro Fx3000 card which has been set at the highest resolution that this monitor can provide.it has been working smoothly since the past few months.,but since tha past 10 days, the monitor screen zooms in and blanks after just 3 mins of on time. when this happens i have to switch the monitor off and wen put on again it comes on for nearly 5 mins and again the same thing happens...i need to have the problem fixed urgently... cud anyone please please help me.most urgent...
  • 10 Answers
SOURCE: monitor power problem
It sounds like an internal issue, more likely the LOPT components are overheating, possibily due to dust collection causing temporary shorts, or an arcing capacitor. The randomness is due to weather conditions, high humidity more likely to monitor wil shut down, the dryer the weather the moisture in the dust would have evaporated, resulting in nothing happening, and a working monitor. I suggest trying this first:- Unplug the monitor from the outlet, and the computer, open the case, but REMEMBER! the monitor can still pack a punch even when it's unplugged from the outlet, (once the case is open, it is completely safe if you accidently brush against a metal part, but under no circumstances (unless you know what you're doing) remove the rubber cap that's either on the top, bottom, or sides of the back of the screen, doing so can result in a massive jolt of up to 20,000 volts),use a can of compressed air to blow out the dust, making sure you clean right up to the control buttons on the front, screw the case back in place, then try the monitor, if it's still the same, and unless you are a qualified electronics engineer and would like to repair the monitor yourself, I suggest you take it to a repair shop.
Posted on Jun 18, 2007
  • 579 Answers
SOURCE: Monitor displays breifly then goes to blank screen
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Posted on Jan 10, 2008
tantong
  • 138 Answers
SOURCE: Screen's gone blank and the green power button flashes intermittently
This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
SOURCE: Screen shrinks monentarily then zooms in untill screen is blank, then turns off.
I had a similiar issue that caused all my Microsoft applications to zoom out to 500%. It also caused PDF documents to shrink and go the the last page. The issue was caused by the Intellatype software that came with my ergonomic keyboard. The issue was resolved by disabling the zoom feature of the sofware on the zoom tab.
Posted on Aug 07, 2008
Monitor does not display
Try resetting the connection. Or make sure that the cable is properly plugged in.
Dec 05, 2012 | NVIDIA Quadro NVS 120M
Nvidia geforce3 (nv20) double monitor set up
Step 1 Make sure the second monitor is connected.
Step 2 Right-click on the Windows' desktop, then select Properties. This will open the Display Properties dialog.
Step 3 Select the Settings tab. This is where you set your monitor resolution, we'll come back to that...
Step 4 Click on the Advanced button. A number of tabs be displayed, select the NVIDIA tab that says "Geforce xxxx " or "Quadro xxxx ". The "xxxx" will be the model of your graphics card. Click the button here labeled Start the NVIDIA Control Panel.
Step 5 In the Task list on the left, under Display, select Set up multiple displays. Then set the nView Display Mode parameter to Horizontal Span. Click the Apply button.
Before proceeding, confirm that the second monitor is now working.
Step 6 Set Touch's settings for the second monitor as described int he section below.
Feb 18, 2012 | Computers & Internet
Stretched screen
For best graphics and zero stretch select the highest resolution that your LCD supports. Which is the resolution of 1440X900
Right click on your desktop and select properties.
Click the Settings tab.
Slide the resolution Bar to the resolution of 1440X900
Also select (Highest 32Bit) colour quality on the right of the resolution bar.
Click Apply then Ok.
If you are not able to select the resolution of 1440X900 then you should update your graphics card drivers to the latest version.
To download the latest drivers for your graphics card click here.
Select the following:
Geforce
Geforce 5 FX Series
Geforce FX 5500
Select your operating System
Select your prefered language
Please be sure to rate this session.
Take care!
Norman-Wynne Damstra
Nov 14, 2011 | Belinea Maxdata 1925 S1W LCD Monitor
Hi, I can abel to connect up to 3 Monitors with my HP NVIDIA Quadro NVS 450 512 MB PCIe installed my Fujitsu Industrial PC . When i connect to 4th Monitor Blue Screen appears which result in Boot...
no idea what you are attempting,
this is HP forum, not Fujitsu, in any why.
never ever post EMAIL here
unless spam for 1000s years, is fun? wow, be bad that.
connect a 4th monitor at the same time?
tell each step, or show what you have there, we cant see you or it.
my wild guess is monitor 4 is bad.
but my inputs are weak there.
test the bad monitor yet, on and other PC? be like wise.
Jul 10, 2017 | HEWLETT-PACKARD Quadro NVS 450, (512 MB)...
Monitor displays message "Out of Range" when trying to set the resolution to 1600x1200 I have NVIDIA Quadro NVS 160M video card with native NVIDIA driver installed
The max resolution to your monitor is 1680x1050. The video card can't help you with the resolution if the monitor doesn't support it.
Sep 24, 2009 | BenQ G2000WD 20 inch Monitor
Poor Resolution on Monitor 2
what u can do is.... 1) Backup your Registry first
2) go to Regedit....Start>Run>Regedit
(this is assuming u have latest Nvidia driver's installed)
HKEY_LOCAL_MACHINE/Software/NVIDIA Corp/Global
In global. Make a new KEY called NVTWEAK
In this key, make a new DWORD value called Coolbits now, change the value of coolbits to 3.
Now when you do into Settings for GFX and advanced settings....you will notice a CLOCK SPEED/FREQUENCY tab. Change them.....go up like 20mhz....or 30 or 50...too high will screw ur card...too low isn't worth the trouble.
So, slowly go up little by little until you notice s--- on ur screen that's dodgy..then just fall back behind that Freq.
Also....another fan taking heat AWAY from the GFX card wouldn't do any harm either.
Don't forget to rate this solution.
Feb 20, 2009 | XFX GeForce FX 5200, Graphic Card
Dell Precision Workstation 670 has no video on screen.
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
Although it may not be your video card thats the problem. when youre computers posts, it beeps once. If it is beeping more then once youll want to check with the board manufacturer to see what the code its giving means.
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Screen resolution resets to 800x600 after every reboot when d/port is connected.
You may have to set the monitors resolution to match the pc as they may be different.
Jan 13, 2007 | Dell Latitude D620 Notebook
Computers & Internet Logo
29 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
