Question about Sony Playstation 3 (PS3) Console
Dropped ps 3 console front cover base is chipped
On the front of the ps 3 on the top right corner a piece has been chipped of by dropping how do i fix this or can i buy new case
  • 53 Answers
Go to the sony website and contact them
Posted on Dec 13, 2008
My son dropped his brand new DSI and the corner chipped and now the top corner button will not work. He needs it for his favorite game, so you can imsgine how this is going! How and where do I get it...
It is extremely unlikely that you can get it fixed in an economically sensible way. I have never seen a console repair place fix portable systems because they require such a high level of expertise. Your best bet is to return to the store you bought it from and see if there is a warranty that covers the damage. If a warranty applies, most likely they will just give you a new DS. If not, contact Nintendo. They do repair their consoles, but is very expensive, and it may just be better to buy a new one.
Mar 10, 2011 | Nintendo DSi Black Console
My PS3 does not turn on ,..the yellow and red light blinks
You've got the YLOD.
Here's a DIY tutorial on how to fix but I recommend getting it fixed by Sony direct!
Oct 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not start-the green light and hard drive starts up for a few seconds then shuts off
The problem is a hardware problem, which is due to a failure in a component it the unit.
You will have to dismantle the playstation, clean it and couple it back together. To dismantle the playstation, follow the steps below:
1.
  • Pull the warranty sticker off of the bottom of the PS3. This will void your warranty, so make sure that the problem you are addressing is not covered by your warranty. Note that taking your PS3 to be repaired by someone other than Sony will still void your warranty. You are not losing anything by taking apart your PS3 yourself. Under the sticker will be a small piece of rubber that hides a single screw. Remove the rubber piece and unscrew the screw.
  • 2 Slide the faceplate off of the PlayStation 3. After the faceplate is removed, you can now separate the two halves of the plastic covering. Remove and set aside the top piece of the plastic case to expose the internal components of the PS3. On the underside of the top plastic covering, there will be a memory card slot at the bottom-right corner.
  • 3 Locate and remove the Bluetooth circuit board. Remove the four screws to lift the Bluetooth board free. This is located at the bottom-left corner of the main body of the PS3 if you have the system flat on its side instead of standing up straight. This will look like a green rectangle with a tan metal covering.
  • 4 Locate the small circuit board that controls the power and eject functions of the PlayStation 3. Remove the four Phillips-head screws in order to separate this piece from the body of the system. This is located at the bottom-right corner of the PS3, directly in front of the disc box.
  • 5 Locate and remove the Blu-Ray/PS3 player. This is the large tan metal box that is located in the top right corner of the PS3. Unscrew the player and flip it upside down to expose the circuit board that controls it. If you want to remove the circuit board, there are five small screws that hold it in place.
  • 6 Remove the power supply from the inside of the gaming system. This is located at the top-left corner inside the PS3. To remove this component, there will be two telephone-like plugs that have to be unplugged, one at the top and one at the bottom of the power supply. Additionally, there will be 13 screws that hold the power supply in place. The back and front plastic coverings of the PS3's shell will now easily slide free.
  • 7 Remove the final internal component, which is the PS3's motherboard. In order to do this, remove the metal covering the rests on top of the motherboard. There will be 11 screws that border the metal covering as well as four screws in the very center, two from each of the rectangular center pieces. Once the screws are removed, the metal covering will lift off and the motherboard will be able to be removed.
  • Have it cleaned and properly reverse the process to reassemble it back together.
    Note: If you are still under the warranty period of purchase, you can take it back to the dealer that supplied it to you for their technical support.
    Take care and good luck
    Is their a way to open a PS3 counsole, my kid might of put a couple of dvd movies in it, it turns on but then shuts down and red light flashes
    To open your ps3, you need to first shut it down and disconnect all the cables connected to it, wait for about an hour for the high voltage in it to dissipate. The you get a screwdriver that matches the screws on it.
    But before you get to all these parts you must have gotten your DVD movies out.
    Take care
    Oct 11, 2010 | Sony PlayStation 3 40GB System
    I have a Lexmark color printer, I can't find where the ink goes in?
    if it's a flatbed scanner model, the whole scanner assembly on the top is larger than the printer portion below. if you lift up on the front corner of the larger scanner assembly, you will see the ink cartridge carriage tucked under the left or right far side when the printer is not printing. power the printer on, lift up the scanner assembly, and wait for the ink cartridge carriage to move itself out from being tucked off to the side. you will see a clip on the front top corner for each cartridge. gently pull forwards (the clip) with your thumb, and the cover will pop open to take out the old cartridge.
    ps. remember to take of the piece of tape that covers the jet nozzels on the new cartridge before inserting cartridge into carriage.
    Sep 26, 2008 | Lexmark Office Equipment & Supplies
    Overfill problem
    with putty knife press clips on each corner about 2-3 inches fron side front drops off ck small almost clrar hose left side that plugs onto side of tub be sure it is clean on end ..they are bad about plugging up right at end ..if still have overfill problem see if water continues to run in with power removed if so fill valve bad to late for cleaning if water shuts off with power removed suspect water fill switch..remove screws along back edge of console and roll console forward to acess
    Jul 23, 2008 | GE WBSR3140DW Top Load Washer
    FLSE72GCSA top drum glide
    remove screws holding console on ..2 on bottom rail and 1 in each lower corner of console they are recessed .console will drop slightly and off 1 screw in each corner of front panel be sure to not loose them they go in these spots only..flat heads..recommend removing large front panel between 2 units remove blower housing 2 clips or screws each corner lint screen housing on inside..reach through and remove belt this will make reassembly easier by removing downward pressure on drum ..
    Jul 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
    Kenmore wascher machine
    ARE YOU WANTING TO REMOVE THE TOP COVER?
    IF THE WASHER IS LESS THAN 25 YEARS OLD, THE TOP DOESN'T COME OFF BY ITSELF. IT IS ATTACHED TO THE CABINET WITH SCREWS FROM UNDERNEATH.
    THERE ARE EITHER TWO SCREWS IN THE LOWER FRONT CORNER OF THE CONSOLE OR IN THE REAR CORNERS OF THE CONSOLE. REMOVE THOSE TWO SCREWS AND SLIDE THE CONOLE FORWARD AND PIVOT UP AND BACK OUT OF THE WAY. THERE ARE TWO CLIPS THAT HOLD THE CABINET TO THE BASE. REMOVE THE TWO CLIPS BY INSERTING A FLAT BLADE SCREWDRIVER IN THE FRONT HOLE THAT THE CLIP GOES INTO. PRY BACKWARD AND UP ON THE END OF THE CLIP TO RELEASE IT FROM THE CABINET. UNHOOK THE PLUG IN THE BACK THAT GOES TO THE LID SWITCH AND TIP THE ENTIRE CABINET TOWARD YOU AND LIFT OFF OF THE BASE. THIS WILL GAIN ACCESS TO THE MAJOR COMPONENTS.
    Apr 07, 2008 | Kenmore 22422 Top Load Washer
    Sony Playstation 3 (PS3) Console Logo
    42 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
