Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Idle problems after throttle is closed fast.
Need some technical help with my 2002 Yamaha SXViper 700. I took of the carbs and cleaned them out the other day and now im having some problems that I cant seem to track down. The sled starts and runs great the only problem is when I rev it up high and let go of the throttle it will cough and sputter when it get to about 3000rpm. If I hit the throttle again it just boggs down and will not rev up. After it has down this I have to let it sit for about 5sec until it stabilise at idle than it run great again. It will only do it if I drop the throttle, if I let it out slowly it runs fine. Any idea on what wrong, thanks for any help you can give.
  • Mel Jacobson
    Mel Jacobson May 11, 2010
    You have a shop manual for your bike ?
  • 91 Answers
Sounds like an overly rich condition when you let throttle snap shut no air enters or at least minamal air enters the engine and with to much gas the engine will bog down until the extra gas burns off(5 seconds) check floats height and make sure jets are secure and make sure the choke is all the way off
Posted on Jan 03, 2009
2002 Yamaha yzf 600 rpm stays hi when reved
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Motorcycle revs stay high after rolling off throttle motorcycles
YZF600R Idle Problem Rev Problem
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Sep 08, 2013 | 2002 Yamaha YZF 600 R thunder cat
1969 Datsun 1600 pickup Fast Idle
Could be the fast idle cam for the choke. When the choke is closed the fast idle cam holds the throttle open until the choke opens.
The cam should be on the opposite side of the throttle cable.
Aug 14, 2012 | 1969 Datsun 1600
YZ426 idle probs
Hi, Mike and the usual suspects are:
1. Throttle cables improperly adjusted or pinched.
Other yz426 idle problem
YZ426 Hanging idle Intake Jetting Fuel Injection
Yamaha YZ426F Owner Service Manual
Yamaha YZ450F Owner Manual Page 3
May 25, 2012 | 2002 Yamaha YZ 426 F
I have a 1986 Yamaha MaximX 700, i have cleaned the carbs with carb cleaner and seafoam, but when i start it, the only way to keep it running is having the choke all the way on and twisting the throttle...
Hi, Caseytkerns and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
How to Clean Motorcycle Carburetor the RIGHT way Evan Fell Motorcycle Works
How to clean motorcycle carburetors
Yamaha XJ700N Service Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Aug 11, 2011 | 1986 Yamaha XJ 700 X Maxim
I have a 2004 yamaha 650 v star custom, and it set for about 6 months, so we removed and cleaned the carbs, and put new spark plugs on it, and it started but wont run off choke also if you drop it into...
sir,please check your throttle cable from handle grip to carburetor i think your cable is not good.because of the idle.or you need to adjust also your air screw and gas
Apr 27, 2011 | 2004 Yamaha V Star Classic
Yamaha yfm 200 blaster need to know how remove the top of the carburator?
THEY MAKE A CARB TOP KIT THAT ELIMINATES THOSE CRAPPY OVERIDES,1 KIT COMES WITH A TWIST THROTTLE OR LEAVE THE THUMB THROTTLE EITHER WAY YOU GET A NEW CARB TOP,THROTTLE CABLE BUT THEN YOU NEED TO GET THE IDLE SCREW KIT FOR IT,WHITCH COMES WITH A IDLE SCREW AND A TAP AND DIRECTIONS.YOU NEED TO DRILL ,THEN TAP ON SIDE OF CARB ,CLEAN CARB OUT INSTALL YOU CARB SLIDE TILL TOUCHES BOTTOM THEN TURN SCREW IN TILL U JUST SEE THROTTLE BODY MOVE AND YOUR IDLE SHOULD BE CLOSE.MEANWHILE U MAY WANT TO PULL YOUR PLUG AND CHECK FOR SPARK BECAUSE WHEN YOU ELIMINATE THE OVERRIDE SYSTEM YOU MAY HAVE TO CACEL OUT THOSE WIRES IF SO THE MAIN HARNESS THAT HAS THOSE WIRES IN IT YOU JUST CRIMP ON 1 OF THOSE BLUE **** SPLICES AND IT DOES A NICE CLEAN JOB AND YOUR CARB IS EASIER TO SERVICE JETTING WISE IF YOU EVER DO ANY PERFORMANCE UPGRADES DOWN THE ROAD,THATS ALOT OF TYPING HOPE THIS HELPS AND FOR THE 100 TO 120 DOLLARS IN PARTS IT IS WELL WORTH IT,BRAND NAME IS MOTION PRO
Mar 17, 2011 | 2001 Yamaha TW 200
Yamaha r1 fast idle
Hi, Tom and the usual suspects are:
http://www.r1-forum.com/forums/4-mechanical-help/248309-05-r1-high-idle.html
04 R1 high idle when warm Biker ie Forums
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 03, 2010 | Yamaha YZF-R1 Motorcycles
My yamaha yzf600 sat for 3 years, it will idle but dies when i give it throttle, it has new gas,fuel filter,sprayed carb cleaner in carbs!! new air filter.
You'll need to disassemble your carbs and manually clean the jets, and ensure that if you have CV-type carbs, you can see all the needle holders rising when you roll on the throttle.
Jul 24, 2010 | 2002 Yamaha YZF 600 R thunder cat
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
2005 yamaha yzf 250-unstable idle
I had the same problem, Turns out that my shims were finished, replace the chims and check clearences.
Mar 12, 2009 | 2004 Yamaha YZ 450 F
Lands Phones Logo
143 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
