Question about Casio FX-9860G Graphic Calculator
Casio fx-9860g Slim won't draw graph in GRAPH
I'm learning how to use the fx-9860G Slim Graphic Calculator.  I'm following the example in the manual to graph y=3x^2. I enter graph from the menu, input 3, x theta T, x^2, exe.  Then I hit F6, draw.
The calculator flashs the function at the top of the display screen and then a thick dark line appear across the bottom of the screen.  This happens in conics, too.  But I can get it to draw plots in the STAT mode.  I've changed the battery and poked the P key.
What am I doing wrong?
marsrover
  • 682 Answers
SOURCE: Installed a wrong OS update version
get battery out-and install it again(after you return the battery)
Posted on Jul 07, 2008
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
  • 7993 Answers
SOURCE: Casio fx-9860g ............ how to do percent operation
[OPTN][LIST] scroll right till you find %. Press the function first then the number. It gives you the percent.
Hope it helps.
Posted on Oct 01, 2009
  • 7993 Answers
SOURCE: solve comlex equation
I do not understand what you mean by solve complex equations, but if you want to manipulate complex numbers here are the tools you need to enter your complex numbers. Operations and function evaluations do not need special symbols.
b4c488c.jpg Hope it helps.
  • 7993 Answers
SOURCE: how do i generate random numbers on the casio
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates key presses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
Posted on Jul 25, 2010
When I type in a function for y1 and have it in standard form the calculator says range Error. How do I change the range, because it wont let me go to the graph. Which is where I would then click V-window...
A linear function in standard form is of the form Ax+By+C=0, where A is a positive integer, B and C are integers (positive or negative).
The problem is that calculators graph a function given in functional form y= ax+b.Thus to graph a function in standard form by means of a graphing utility you must isolate the y variable. The interesting thing about the Prizm (Casio graphing calculator) is that you select which variable to isolate y (usually) or x if you so choose. To choose to graph the function x=Dy+E you must select the function type as X=.
Sep 15, 2013 | Casio FX-9860G Graphic Calculator
Range error on casio graphing calculator
Open the window configuration ans set Ymin to -10. You can also access the ZOOM function and select Zoom Standard.
May 07, 2012 | Casio FX-9860G Graphic Calculator
Non linear graphs
All graphs, except the linear function y=ax+b, are non-linear. To graph a function, just enter the GRAPH utility, type in the functions Y1=, Y2=, ... and press the Draw tab.
If you have a specific question, ask it.
Mar 26, 2012 | Casio FX-9860G Graphic Calculator
Prime factorization using Casio FX-9860G Graphic Calculator
There is a program called Prime Factor Analysis on this site. It is written for the FX-9750GPlus calculator but I suspect you should be able to use it on the FX-9860G. To access the site you must have an account. You can register and it is free.
Jul 30, 2011 | Casio FX-9860G Graphic Calculator
How can you change the mode on a casio fx-9860g calculator to deg. mode?
Press SHIFT MENU to bring up the setup screen. Use the arrow keys to move to the "Angle" line and press the function key for the desired angle mode.
Mar 04, 2011 | Casio FX-9860G Slim Graphic Calculator
How do i solve negative 15x to the power of 4 divided by 3x
-15x^4 / 3x = -5x³ for x 0.
You should be able to figure this out without having to resort to a calculator. Note the "for x 0"... the two functions are identical everywhere, except the -15x^4 / 3x version is undefined for x = 0 (3 times 0 is 0 and you cannot divide by 0). The function has a "hole" at this point. -5x³ does not suffer from this defect, for x=0 it simply evaluates to 0, so you have to mention this fact to make it proper.
Jan 07, 2011 | Casio FX-9860G Slim Graphic Calculator
I have the Casio FX-9860G Slim, how do i do logs with something other then base 10?
Use the logab function in the catalog. For example, to calculate log base 2 of 32:
OPTN F4 F6 F4 2 , 3 2 ) EXE
Dec 15, 2010 | Casio FX-9860G Graphic Calculator
Casio fx-9860G graphics calculater, vertical line segment
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
May 01, 2010 | Casio FX-9860G Graphic Calculator
How do you do a linear regression graph on a casio graphing calculator?
I am aware that the solution provided below is valid for the CFX/FX-9850G/GB/ but I will supply it. I remain convinced it will help you for your calculator.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
Hope it helps.
Oct 04, 2009 | Casio FX-9860G Graphic Calculator
Casio FX-9860G Graphic Calculator Logo
102 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
