Question about Dell Photo 964 All-In-One InkJet Printer
Dell 946 printer will not print says alignment problem
Ink levels are good. will not print any black & white text
  • 1 more comment
  • reenbow Dec 16, 2008
    My print cartridges won't align either, I've tried the scan thing, no luck. I just installed new cartridges & wish I hadn't.
  • laffabulls Jan 05, 2009
    ink level are fine, but will not print black or blue, barely prints at all, clean print heads utility just prints yellow and red, print alignment utility prints nothing
  • Anonymous Jan 26, 2009
    Same exact problem
5 Suggested Answers
  • 8 Answers
SOURCE: Black Ink won't print properly (Dell AIO 966)
black cartriges bad
Posted on Mar 16, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Dell 946 printer
You need to set the size of your page on the printer preferences.
If you need more help you can see the manual of your printer here: http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Posted on Sep 24, 2008
yooperbud
  • 8637 Answers
SOURCE: Black ink cartridge is 2/3 full, but doesn't print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 53 Answers
SOURCE: reset ink levels on dell 944
If you refilled the cartridges, you may want to try new Dell branded cartridges.
Posted on May 27, 2009
SOURCE: Dell Photo 944 won't print black and white
I had the same problem and just figured it out! On your control panel, choose printer and then Properties. Go to Printing Preferences and click on the Advanced tab. Under this tab is a button for More Options and then a section Complete-A-Print. I had to uncheck "use color cartridge for all black printing" and then check "use black cartridge to print in black and white." Then I had the option back to print in black and white. I have a Dell Photo 964 but I'm assuming the options should be the same. Hope this helps someone!
Posted on Jun 07, 2009
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Are you using Dell Series 5 ink cartridges?
Can you copy a document under the glass? Black & White and color? Do they look ok?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
We keep getting left cartridge incorrect message?
Any error messages?
Rick
Jun 12, 2011 | Dell 946 All-In-One InkJet Printer
Dell AIO Printer 946 I can't print a word document in black and white. When i click on printing preferences, it doesn't allow me to click on " print in black and white" Please help
In printing properties have you selected the 'grayscale' option, if still not working, in printer properties select maintenance > select Ink and cartridge settings > there select "black Ink only"
Jun 01, 2011 | Dell AIO Printer 946
I have a pixma canon printer on a mac os 10.6 system. was printing in black and white fine then it start to have weak print out put then large horizontal bands of text were completely missing now it wont'...
you will have to replace your cartridge, even if the printer still shows a good ink level bare in mind that is only estimativ. After you replace the cartridge you no longer have a problem.
Nov 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Won't print with one cartridge
I can get my 946 to print with just a black cartridge, as long as I select black and white printing (there is an error message on the PC but I can just select 'continue'). But with just a photo cartridge (i.e. a combined black and colour one) it won't work - looks the same, but the 'continue' option doesn't work.
Dec 13, 2009 | Dell 946 All-In-One InkJet Printer
Printer only prints in red!
In this case, i would request you to follow the bellow steps:
1)click on File Menu ->select Print->Select Preference->color tab->Select "print in graey color->now select only Balck ink....
I Hope by following above steps, your issue will resolved.
Thanks
Sushant
Jul 06, 2009 | Dell 946 All-In-One InkJet Printer
I have a dell printer A960 I refilled color cartridge and have not used it for about 2 months and now it only prints in red what can I do
The print heads on your ink cartridges have dried up. Ink printers need to print in black and white and color once a week. Doing this will extend the usable life of your cartridge because the ink will not dry on the print head and clog it. You can try and get the ink flowing yourself by resting the print head on a warm moist paper towel until you see ink on the towel (ink stains most surfaces so be careful where you do this). To check your progress, press the print head into a dry paper towel. You should see three entire distinct colors for the color cartridge and one black line for the black cartridge. If you can't get it flowing again you will need to buy new cartridges. You can get Dell refills from Cartridge World if you would like to save some money.
May 11, 2009 | Dell 946 All-In-One InkJet Printer
Printer creating white lines that distort output
Hello loyasq,
You should do :
1st; Try to fix that by the device's Appliaction
smthing like that
2nd; Uninstall every application for this device and re-install it again.
3rd; If your printer have 1 Cartridge for all colors, Cleanse the part of ink output (the nozzle of ink cartridge) with wet tissue.
Thx for using FixYa.
Apr 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
Jan 02, 2009 | Dell 946 All-In-One InkJet Printer
Dell 946 -carriage jam/stalled
the ink carriage is in far left position and jammed. it appears that the black cartridge far left was not seated correctly. how do i resolve this?
Nov 19, 2008 | Dell 946 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
673 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
