Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I turned my washing machine upside down
Now it wont turn back on will it reset itself--??
  • 706 Answers
Hello d_snarey,
By flipping it upside down, chances are good that the inner works shifted in a manner it was not designed for and that a component, wire or connector got damaged or dislodged so I would doubt that it would begin working on its own. If possible, can you look at the inner works for any sign of damage? Hope you find something obvious like a connector, wire or component that is damaged..
Regards,
Rick
Posted on Dec 13, 2008
How do I reset my servis washing machine 1500 A+A if it wont do it itself?
Un-plug the machine from AC mains wall socket, and re-plug it back after an hour; or so. If you do this over-night will be better. The internal electronic control circuit will reset itself.
Nov 29, 2014 | Washing Machines
Wont stop turning on
It could be the control panel
Mar 30, 2013 | Washing Machines
HOW DO I RESET MY WASHING MACHINE IT IS STUCK ON 28 MINS
Hi. is it stuck on the rinse cycle & won't move on,
Is your machine an IW Eco intuitive Q.
Please let me know your machine model.
Feb 03, 2013 | Fisher and Paykel Washing Machines
Is there an easier way to access the water pump than turning the machine upside down? we havn't found any of the panels that are easily removed. thank you. rvclay
No, unfortunately that is pretty much how you get to it. If you can tilt the unit back about 45 degrees and block it up so it wont tip on you, its not too bad to get at while laying on the floor. just try to get it back far enough that the remaining water is below the pump.
Hope that helps
good luck
May 11, 2011 | Fisher and Paykel GWL11 Top Load Washer
Optoma HD 65 projector, fine last night, today it wouldnt turn on with a light flashing. so i turned it off at the mains and back on again, the image was upside down (i have it hanging on my ceiling upside...
it did do a reset on the settings. The lights do indicate something if you look at the trouble shooting section in your manual. Need to know what lights are on and what is blinking this is a feedback to you. how long ago did you clean your filter. is the lamp needing to be replaced?
May 13, 2010 | Optoma HD65 DLP Projector
Nespresso aeroccino doesn't work after milk was overflowing. Is there some kind of security which can be resetted?
The company will tell you to turn upside down for 24 hours to reset. I did and this did not work, you may have gotten base wet, which can break machine. Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck.
Apr 12, 2010 | Nespresso Aeroccino Automatic Milk Frother
Drum light stays on and wont let me start it again. Its dead but has light.. I have to power down the entire house to get it to start again
I had the same problem. LG addressed the problems as follows:
1. Unplug the unit 2. Press and hold the power button for 10 seconds. 3. Plug the unit back in.
It WORKS!! It's like reseting your computer or alarm clock. You've got to kill the power and press and hold the on button while it's still unplugged.
Hope this works for you.
May 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to remove motor from bosch wfo 2867 washing machine@?
Remove back panrl. Remove drive belt, remove 2 10mm motor bolts. Turn machine upside down. Remove bottom cover. Disconnect power lead to motor, disconnect earth lead, gently tap motor out with mallet. Brush mountings then accessible, remove and replace brushes.
Aug 11, 2008 | Bosch Washing Machines
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
