Need Gearcase oil
Opened gear case to check gears and spillled the oil. Stores with the specific oil recomended needs 1 week to ship it and it is $20.00. Can I substitute regular gear case oil and what weight? This is a Whirlpool Ultimate Care II
  • 85 Answers
You just might want to change out you trans asm pn 3360629 for about
$175 part is not field servicable. even if you know what type or wieght oil then how much?
Posted on Dec 14, 2008
Hi my dewalt d25900k is leaking oil from the plastic caseing on the side of the breaker where the gears are i taken it apart ,i will get a new gasket ,it has lost alot of oil ,what sort of oil do i need...
The gasket your looking for is part# 487224-00 SEAL which lists for $3.65. The gearcase should use LUBCON GLK 249 grease spread evenly across the gears. Be careful with the amount you apply, too little grease will not properly lubricate and too much will create additional friction cause the to motor to work harder, thus reducing its effectiveness and longevity. ONLY THIS GREASE SHOULD BE USED ON THE INTERNAL COMPONETS OF THIS TOOL. Note that the bit grease is different than the gearcase grease and SHOULD NOT be used on any internal components.
5g on connecting rod and piston - inside and out
39g in gearcase evenly coating all parts
39g in crankcase
Jan 18, 2011 | Dewalt D25900K Heavy Duty Sds Max...
What type of gear oil for rear end and how much for 2005 silverado 1500 HD Can I use synth.
The recomended gear oil is 75w90 synthetic. However the capacities
increase with the size of the rear end.
8.6" 2.15qt (2.0L)
10.5+9.5" 2.75QT (2.6L)
9.75" 3QT (2.8L)
11.5" 3.17QT (3.6L)
Hope this helps.
May 01, 2010 | 2002 Chevrolet Silverado 1500HD
Seal a round shaft of transmission leaking what oil does the transmission require
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive washer.
See the following Whirl[pool parts list for their commercial washers although the consumer models use the same transmission and parts.
The part you need is probably the 3349985 Seal, Gearcase
Cover, a relatively cheap part.
I've found that basic 80-90 weight non-detergent gear oil ( available at auto parts stores) seems to work well. It's certainly less expensive than the gearcase oil from Sears.
Feb 12, 2010 | Kenmore Washing Machines
Just bought 95 chevy pu 5 speed manual looks like
Please ensure that this has gear oil because some of these actually ran regular dexron tranny fluid. If it is gear oil a standard 80w-90 is a good all grade gear oil to run in it.
Sep 20, 2009 | 1995 Chevrolet K1500
I need to change the oil in the transfer case but i dont know what kind to use or how much.
your transfer case does not use regular motor will use gear oil which can be purchased at any local parts store or even wal-mart (most part stores can tell you how much you need to add to the unit but a good rule of thumb is add the gear oil until it starts to drip out the fill/check hole..
Jul 30, 2009 | 2003 Chevrolet Blazer
Oil on the floor under the washer
The gear case you are referring to is actually the transmission, and yes this is not a good sign. The seal has gone out. its usually cheaper to get another washer than repairing the old one. However if you would rather repair this one then i would try to shop around and find the best bargain.
Jun 14, 2009 | Kenmore 22622 Top Load Washer
Re: gearcase
Its hard to tell without seeing it. If the clutch is covered in oil (from the gearcase), it may be a good idea to replace it. Otherwise, you can reuse the old one. Let me know if you get to a point where you're stuck and need assistance.
PS The gearcase has specific instructions on the container that it be shipped in the UPRIGHT position. This prevents the gearcase oil from leaking out. In addition, there is a small breather hole on the top of the gearcase, that is sealed with paint prior to shipping. Don't forget to use a scribe or an awl to open this breather hole BEFORE installation.
Oct 08, 2008 | Kenmore 22622 Top Load Washer
Washing machine broken, kenmore model 110.92274100
Apr 22, 2008 | Washing Machines
Kenmore model 110 gear case
you were able to get to the coupler??? if so youre were half way there. first off you will need a gearcase and a clutch assy. 1/2 socket , 7/16 socket adn maybe a reg screwdriver.start by removing the agitator from within the tub, after getting hte fabric softener dispenser off there is an opaque handled cover to remove, the you will see a 7/16 bolt remove it and the agitator will come off, set aside you may also have to remove a small white plastic(something or ohter) with a piece of steel (sorta like a cam/ lock)willlift right off the gearcase, next remove the cover and the pump and disconnect the motor so as you now have access to replace motor coupling.. you ll hten need to tip machine back and remove the (3) 1/2 inch bolts mounting the gear case to the underneath of of the machine and the gear case will now fall right out( litle persuasion never hurt anyone!!, the clutch will mount to the new gear case, and there are detailed instructions as to how in the withthe part
Mar 26, 2008 | Washing Machines
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
