Question about Hannspree XV32 32 in. LCD Television
Need assistance on hannspree 32p
Hello
i have a flat panel tv hansspree, but sometimes i get bluescreens on TV & HDMI sources. Scart is ok. Is there a way to do a factory reset ?
thanks
I've had exactly the same problem and it seems to be happening across a whole range of 2 year old LCD TVs World wide. Replacing the Inverter seems to be the only solution (sometimes but not 100% effective). I'm trying to track down if you can get an Inverter for a Hannspree at all and if it's going to be cost effective
Posted on Jan 03, 2009
    New Friend:
I have television hannspree t191h and in the republic ceh work and now i am in romania and here dont found the chanels,the other comands work very good
Posted on Jan 17, 2016
I have this problem on my 37" Hannspree XV. Any up to date help would be greatly appreciated.
Posted on Nov 08, 2012
When I select a source/scart on my tcl tv, it outomatically moves to other scarts. What do I do?
Try a reset to this TV first. A hard reset.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 03, 2015 | TCL LE40FHDE3000 40" 1080p LED-LCD TV -...
HDMI won't work
Try a new cable.check no debris has lodged in the port for hdmi or at the cable.
Jan 29, 2015 | Televison & Video
Hi! I pressed hdmi button and now nothing is on my analog tv screen,i have no hdmi device and now i dont know how to escape from hdmi mode
Is there a 'source', 'input', or 'av' button?
If so, press that button util the correct source is selected.
You shouldn't have to reset anything.
Dec 23, 2014 | Televison & Video
No signal on tv screen
Is it registering the correct input? HDMI/ AV1/ AV2/ SCART!
Nov 05, 2014 | Televison & Video
How do you connect a potable dvd player?
If the dvd player has a hdmi contact you should use this. In the tv's menu you should be able to define the hdmi contact in use. The same goes for a scart contact. However, if the dvd player has a cart contact only and the tv has no scart contact, I am afraid that you cannot use that player. Anyway, you should consult the manual, that you have been adviced to download. Good luck.
Aug 06, 2014 | Hannspree XV32 32 in. LCD Television
What is the source button on a tv
Source button is to use to select the input sourse; ie, TV / AV / HDMI / SCART.
Electro help
Jul 22, 2014 | Element Electronics Televison & Video
I HVE a ilo tv WHT do I go to in menu to watch my dvd
hi if your using hdmi select hdmi on the tv if your using scart lead select scart on the tv, to get these setting press the source button the remote,the symbol is a box with a line in it. hope it helps
regards
shaun
Jan 30, 2014 | Televison & Video
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Sep 06, 2012 | Hannspree Televison & Video
Trouble trying to connect my dvd player and set it up to my new 42 " L cd lost instructions!
You will need to determine if your DVD player is HDMI or Scart. If you connect it via a scart lead, then it should automatically turn on when you power it up, if not it will be located on your tv under the appropriate source/input label, ie AV1/AV2, or SCART.
If you are using a HDMI lead, then you will have to turn it over yourself, as HDMI does not support switching control. To do this, locate the input button on your remote (sometimes labled source) and press it until you can select the correct HDMI input using either the directional buttons, or by repeatedly pressing the input button.
Hope this helps
TV_Doctor
Jan 03, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Lg 42' lcd cant get video signal i can get sound and menu pictures all come up. but no output from cable or ps3
I guess your either using the scart socket or the HDMI socket. You have gone into the menu and changed your input source to either HDMI or Scart havent you? Does your TV aerial input work when switched to Antenna on the input source menu. If these dont happen then you have a faulty main pcb.
Feb 13, 2010 | LG 42LH40 LCD TV
Hannspree XV32 32 in. LCD Television Logo
1,349 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
