How to install
I would like you to click on this,
http://support.gateway.com/s/Manuals/Desktops/8508951.pdf
The above is a PDF file.
Checking Out Your Gateway E-4000 Computer.
Reason for manual?
There are Three form factors for the Gateway E-4000 series of Desktop PC's;
A) 4-Bay Small Form Factor (SFF)
B) Micro Tower
C) Mid Tower
The above manual covers all three, and also details pictorially, with instructions, on how to replace the Power Supply.
After the file has downloaded, go to the Bookmarks menu to the left.
Click on the + sign to the left of - Adding or Replacing Components.
Now click on the + sign to the left of the form factor of desktop computer you have.
Scroll down a little, and click right on - Replacing the Power Supply
IF, you have ANY problems, come back here, and state so in a Comment. I will gladly guide you.
(Power cables? Where they go? Etc. )
Regards,
joecoolvette
Whoa! Forgot to add; BEFORE reaching inside your computer FOLLOW Anti-Static Precautions! Anti-Static Precautions; Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer. Relieve your body of Static before reaching inside your computer. Computer on a table, computer Unplugged from power, computer case open. TOUCH an unpainted surface, of the metal frame of the open computer case. This action will relieve your body of Static. SHOULD you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
