Question about Aiwa NSX-DS55 CD Shelf System
Cd player loads but does not play aiwa nsx-5200
How do I get the cd player to play?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Clean optical lens, this might help to play cd.
    Still no go, optical lens would be defective and needs to be replaced.
  • 247 Answers
First make sure the optical eye is clean. Use a cotton swab. If that doesn' work try the following if you are somewhat handy.
To start with, make sure that your CD player is suffering from the problem that this method is designed to fix. This method is designed to fix a misaligned CD read head. The common symptoms of this problem are:
1. You place a CD in the player, and it spins for a bit but never finds the list of tracks on the CD and returns some kind of error. This problem may occur regularly or intermittently.
2. CDs tend to skip frequently, even if they are clean and in good condition.
So if this sounds like your problem, then this method is for you. You should however bear the following in mind: only attempt to fix the CD player if the fault occurs frequently and is really annoying; i.e. if you are thinking of throwing the CD player away. To carry out the repair you will have to open the case. This will certainly render void any warranty the device might have, so if your player is still under warranty, don't open it. Simply return it to the retailer. Finally, for your safety and that of your equipment be sure to disconnect your CD player and remove any batteries at least a half hour before you start work. Finally, although I have had consistent success with this method, everything you do is at your own risk and is your own responsibility. I provide no guarantee of any nature regarding this method.
Your first job is to open up the case of your CD player. This will be more or less difficult depending on the type of device. If you are lucky and have a Hi-Fi separate type device then it will be pretty simple; if you have a mini or midi-system with a built in CD player this could be trickier. Fixing portable CD players (e.g. a Discman) is probably only for the uber-patient as it is likely to be very fiddly. The main thing required here is patience and a methodical approach. As you remove screws put them somewhere safe; line them up in the order in which you removed them, or make notes of what goes where. You may reach a point where you think you have taken all the screws out but you still can't get into the case. Here, patience is still the key. Check under stickers for hidden screws or clips. Try and work out where the case is held together. Use the minimum force possible at all times.
Now, assuming you have managed to get into the case successfully, and have got access to the CD player we can continue. By now you will probably be able to see the CD tray (the bit that holds the disk) and also some kind of arm which hovers over the disk when the tray is closed. There will usually be a small motor for moving the lens over the disk, and attached to this or nearby there is typically a small circuit board.
On this board, or in any case rather close to the read head there can usually be found a small potentiometer (sometimes referred to as a pot). This will usually be a small square component with a plastic disk on top, and this disk will have a slot which is designed to take a small flat head screwdriver. This is what we will be adjusting.
However, before doing this it is advisable to use an indelible marker pen (magic marker) to mark the current position of the Potentiometer, so that it can be returned to its original position if necessary. With this done then we are ready to start fixing your CD player.
This is essentially a trial and error process. You make a small adjustment to the position of the potentiometer, then try the CD player and see if it is improved. In my experience generally only small adjustments (less than plus/minus 30 degrees of rotation) are usually necessary.
Depending on how comfortable you are working with electrical devices there are different ways of going through this trial and error process. If you are unsure of yourself or particularly safety conscious then will probably want to put the case back on the CD player each time you test it because you will probably have to plug it in to do this. However, as you have probably guessed it is not necessary to put all the screws back in.
Kurt
Posted on Mar 17, 2009
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
Aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Dec 06, 2009 | Aiwa Audio Players & Recorders
I can't activate the CD Player on the Aiwa NSX-2700
Either the glass laser eye lens needs to be cleaned with rubbing alcohol and cotton swab, or the laser lens unit itself is faulty. You may be able to get one from ebay, newegg.com, amazon.com or etech.com
Sep 16, 2009 | Aiwa NSX-2700 Shelf System
Good morning, I need your help for my Aiwa NSX-SZ50 digital audio system .... It went in demo mode, what can I do to start again ???? It is possible to have another manual ??? Many thanks for your...
you can order new owners manuals online in many places. Search for Aiwa NSX-SZ50 owners manual.
I would try unplugging it, and then play a cd... it should snap out of it. if not, look through any menus you can access.
Aug 19, 2009 | Aiwa Audio Players & Recorders
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs
www.devicemanuals.com/company/AIWA-manuals-page9.html - 49k -
djdizzys
Feb 18, 2008 | Audio Players & Recorders
CD-R Playback Issue
check the laser eye of your player clean or replace.
Aug 28, 2007 | Aiwa NSX-A115 Shelf System
Aiwa NSX-DS55 CD Shelf System Logo
427 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
