Paper feed is going through at an angle, causing a paper jam
Have tried disconnecting, restarting computer etc still causing problems when printing starts
  • 26 Answers
Hi
please let me know ,
what kind of printer you have , such as: brand name, what series , what oprating system you have on your pc and what kind of problem you get , so we can assist you to solve it.
thanks:Marco
Posted on Dec 13, 2008
While copying mode, and paper feeding into printer, the sheet was pulled to remove and it jammed causing an error message to be generated. (Contact Epsom support). After restarting printer, print comes out...
To clean your Epson Stylus > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
This will solve the paper jamming problem. Hope this helps, please rate if the solution was helpful, thanks!
Sep 02, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
The printer doesnt feed the paper properly, it takes it in at an angle and jams. I have tried everythign to sort it.
when the printer does not appear to respond to commands. This can include attempting to print from the computer or on the device itself. This can happen when the memory in the printer does not refresh properly. One way to correct this problem is to restart the computer. Another way to correct this problem is to disconnect the printer from the wall outlet. Wait about ten seconds and the plug the printer back into the outlet. This should reset the memory on the device and allow it to function properly
Read more: Canon MP520 Troubleshooting ' eHow.com http://www.ehow.com/way_5206602_canon-mp520-troubleshooting.html#ixzz167nuebzB
Nov 23, 2010 | Canon MP520 All-In-One InkJet Photo...
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Lexmark X5400 Series AIO Feed Problems
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks, Anu
Jul 20, 2009 | Lexmark X5495 All-in-One &USB...
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Paper jamming
You have almost certainly got a foreign object in the paper feed path as there is nothing on the L/H side that should cause an obstruction. First of all turn the printer off & disconnect all cables. Turn the printer upside down and give a good shake, with luck the blockage should fall out. If not then you need to be a bit brave, make sure the print carriage is parked fully right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Apr 10, 2009 | Epson Stylus Photo R300 InkJet Printer
Paper going thru at an angle and jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper feed on my Pixma MP500 printer is not working. The paper gets stuck
I can help you but need a bit more information.
Are you having more than one page entering the print task and those 'pages' are getting jammed.
Or, is the paper feeding at an angle and this is causing the jam.
Or, is the paper getting stuck on exit of the rollers and jamming there.
Regards,
Worldvet
Jul 11, 2008 | Canon Office Equipment & Supplies
Won't print
Sounds like a piece of paper is stuck inside the machine. Open all access doors and check. Remove the printer cartridge and reinsert. Make sure the print job has been purged from the queue.
May 31, 2008 | Lexmark X73 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
