I believe our model is the same as these. No matter what wash cyle we set it on it flashes the time lapse of the cylce, we close the door and press start. It just flases the cycle time for a minute or so then shuts off. Seems to be a proble within the panel. Any ideas? Thank you,
My manual says: 1- Close door. 2- Select cycle. 3- Press delay. 4- Push Start/Cancel. (As soon as start/cancel is pressed, the flashing should stop and the delay time will begin).
our mdb5600a does not drain completely,the drain hose is clean any thing else besides the pump...
(More)
our mdb5600a does not drain completely,the drain hose is clean any thing else besides the pump couldcause this??? where is the air gap?
How old is the Maytag mdbh945awb3 dishwasher ? I have one in a box that the man says is the new...
(More)
How old is the Maytag mdbh945awb3 dishwasher ? I have one in a box that the man says is the new model. Are there known problems with that model? Thanks! Marcy from Buffalo NY
Unit appears to be loose under the counter. Bottom can be pushed in about 2 inches. Top appears to...
(More)
Unit appears to be loose under the counter. Bottom can be pushed in about 2 inches. Top appears to be mounted but should go under the counter further. How do we adjust the mounting??Its a jetclean II dishwasher but not sure of the model might be wu104 serial number is 115807BM
maytag model MDB7160AWB dishwasher fills and starts wash cycle. approx 2 min into cycle it shuts...
(More)
maytag model MDB7160AWB dishwasher fills and starts wash cycle. approx 2 min into cycle it shuts down
