Question about Brother SE-270D Computerized Sewing Machine
My bobbin shuttle broke and I can't find anyplace on line to orde
Er from. I live in a rural area with no brother dealers closer than 100 miles. A website would be most helpful.
    Problem Solver:
  • 9 Answers
Do a search for "sewing machine parts" and look at the web sites to find what you need, or email them for your part.
Posted on Dec 13, 2008
My needle keeps hitting the rotating hook complete plate and breaking. I messed it up when I pulled on some thread stuck in the bobbin case. I live in a rural area. How do I fix this.
First remove the bobbin and the bobbin carrier shuttle. Check behind it. Then carefully replace it, making sure it locks into the correct spot. If it continues to do it, then you need to take it to a repair shop to fix the timing.
Nov 23, 2016 | Sewing Machines
How to remove sewing bed where fabric lays when sewing to get to bobbin area of Brother LS - 2020 sewing machine
Lower bobbin threading Brother
  1. Turn the power switch to "o".
  2. Raise the needle to its highest position by turning the balance wheel towards you (anti-clockwise) and raise the presser foot lever.
  3. Open the shuttle cover behind the extension table on the the front of the machine and remove the bobbin case by pulling its latch towards you and pulling it out of the shuttle race. (fig A).
  4. Unwind about 10cm (4") of the thread from a full bobbin and insert it into the bobbin case. (see fig B-1). Pull the trailing thread into the slot then down and to the left, as shown in fig B-2, until it enters the delivery eye under the tension spring (fig B-3).
  5. Holding the bobbin case by the latch, fully insert the bobbin case into the shuttle race and release the latch. Make sure the bobbin case finger fits into the notch at the top of the race as shown in fig C.
Sep 13, 2016 | Brother Sewing Machines
Bobbin shuttle doesn't move
Look in your book.
- There is a bobbin (clear plastic) it rotates.
- The bobbin fits into the bobbin case (black), it does not rotate.
- The bobbin case is nested into the shuttle which does rotate.
There is no bobbin shuttle.
Aug 19, 2014 | Brother CS-8060 Computerized Sewing...
Bobbin case
I would recommend using an authentic bobbin case and bobbins for your Bernina. Your dealer will have them. Just be sure to tell them the model you have.
FWIW, you can remove the shuttle hook and bobbin case by turning the 2 little black levers at the bottom right and left in the bobbin area, Once you do that, the circular piece that holds the bobbin mechanism in place can drop down and the bobbin case and shuttle hook can be removed as one unit. You should probably do this frequently to brush out the lint and debris and to oil the "shelf" where the hook resides. Oiling the hook shelf should be done about every 8 hrs of sewing.
Here's the manual for your machine:
The aurora 440 QE sewing machine for everyone and every application
Nov 29, 2017 | Bernina Sewing Machines
What is a shuttle on a Brother XL3500? The shop tells us we need to order one from the US (we live in Paraguay) and I can't find one online!
Hi, I checked your sewing machine & it doesn't have a shuttle, it has a bobbin & bobbin case, there is a website where you can find part for your sewing machine, it's
hope this help you
please rate this with the thumbs in the upper right hand corner-thank you
Aug 06, 2010 | Brother XL-3510 Mechanical Sewing Machine
The safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
Mar 03, 2010 | Brother SE-270D Computerized Sewing...
I have a Brother NX-200 that keeps locking up with an error code E6. I have cleaned all lint from the shuttle and needle area. It began sewing again and then locked up on me again
Power off.
Remove the bobbin and bobbin case. Recheck the area around the shuttle for thread snips.
Power on.
If the problem continues you will need a professional to check the machine - It may need a more thorough cleaning than what the mfg allows the user access to or a new sensor.
Feb 28, 2010 | Brother Sewing Machines
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
238 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
