The paper jambs when I press print - Office Equipment & Supplies
  • Anonymous Jan 11, 2009
    Just installed the printer and started to print but each time the paper jams. Nothing I do stops the problem.
  • Anonymous Apr 26, 2009
1. first of all you will open the printer by unscrolling it,and remove the paper that is inside the printer
2. corple it and run the test
Posted on Mar 27, 2009
MFC 240C print quality is excellent but prints crooked on page. Ran alignment multiple times, no help.
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Brother Multi-Function Center MFC-240C...
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
A paper jam on my canon ip4800 caused the print to be misaligned. now the edges are not straight. help!
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Sep 06, 2011 | Computers & Internet
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
The paper is not going in straigh to be printed. its getting jammed but there is nothing in the way
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Printing is out of line
Jul 04, 2011 | Canon MX700 Office All-In-One InkJet...
Paper jams after printing a few copys. Shows error 19
Jun 17, 2011 | Office Equipment & Supplies
Printer will not print.a photo paper went thru on a angle. now it will not print.
A paper jamb could be caused by dirty orsticky rollers, also failure to remove all traces of paper from a previouspaper jamb.
May 28, 2011 | HP PSC 1315 All-In-One InkJet Printer
Printer prints fine on its own. Will not print
Try the following steps.
Press in the tab on the left side of the rear clean out door to release the door.
Remove the door from pulling it away from the printer.
Look for any paper bits /paper and removing a paper jam from the front may damage the printer.
Replace the rear door and press Cancel/ Resume to continue printing.
After this,
Uninstall and reinstall the software with the CD provided by the manufacturer. Turn off printer and system.
Remove the data cable and the power cable from the printer.
Press the power button for 20 seconds.
Aug 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
60 people viewed this question
jasbo
jasbo
