Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Programming remotes for garage door
I purchased a model 35390 and install went fine. I tried to program the remote built into my 2004 nissan and it would not work. I reset the two remotes I got with the opener and they both work fine. I then tried to program my built in car remote again and it would not work. The key pad won't work either. I follow the process of pressing and releasing the learn button, then holding down the remote button. For the keypad I pressed the learn button, then put in a four digit code and held the enter button
  • Anonymous Mar 16, 2014
    learn code button light fails to come on when pressed
  • Anonymous Mar 21, 2014
    learn button does not stay on when programming remote
    Champion:
  • 244 Answers
Sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Posted on Jan 15, 2009
I have a Craftsman 41A315-7D garage door opener. I can program one or the other of the two remotes I own. Either one will work fine but I can not get both to work. Its one or the other... not both. The...
You can program more than one remote if they are the same model number and/or the same technology. If your remotes are the same model number then one has converted to an earlier technology. You will need to purchase a new remote and then you will find that the new one will work with one of the old remotes but not the other. Get rid of the bad remote to prevent complications in the future.
Oct 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Unable to program remotes from opener
TRY UNPLUGING THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN CLEAR THE CODES BY HODING DOWN THE PROGRAM BUTTON FOR ABOUT 20 SECONDS.
NOW YOU ARE READY TO PROGRAM A REMOTE TO THE SYSTEM.
HOPE THIS HELPS
Aug 13, 2009 | liftmaster Chamberlain Garage Door Opener...
Just moved, no garage remote, need to set the opener in my SUV.
The garage door opener is needed to use the HomeLink system that is in your vehicle. This design is so that no one can program theirs to gain access to your garage. You will have to obtain a working remote and it will have to be programmed at the garage door.
Jul 13, 2009 | 2004 Nissan Maxima
I CAN NOT PROGRAM MY BUILT IN CAR REMOTE ON MY NEW 139.53985DM
didnt try everything cause if you did, it would work! Get two people and garage door opener. One read manual from car under Garage door" or Homelink while other pushes button. When manual says if this did not work or if you have security plus or rolling code, continue with other instructions. You will need a working remote and will need to pushh learn button on motor logic board.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming the garage door opener
I know what the problem is but never tried to resolve it. I have a 1998 XJ8 and went through the same problem. After numerous attempts to program the 4 channel built in opener I researched the problem and learned that the system in the car actually changes the code after every use. It's a security feature built in to the system. I simply started keeping my remote in the car.
There must be a way to disable the automatic randomizer so it retains the code from your remote opener everytime. Check with the dealer to see if it can be disabled and you will be in business. Please post the info if you get it.
Good Luck!
Nov 24, 2008 | 1998 Jaguar XJ8L
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
190 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
