Question about GE 30 in.Profile JGP940 Gas Cooktop
Gas leak within cooktop
My jgp940 glass surface cooktop seems to leak from within, wether in use of not.
I have to fix it myself as we are 1200 miles from a dealer or any type of expert.
Problem is I cant see how to get access inside the cooktop, and don't want to break the glass upper trying.
Once inside I'm sure I can fix the leak.
  • interd0g Dec 16, 2008
    Thanks for the detailed directions.
    In answer to your question, it seems to leak gas.
    To make sure I capped off the pipe to it, right at the flare.
    The smell stopped.
  • 111 Answers
What do you mean it has a leak inside? You can remove the glass top by carefully lifting it up and out of the countertop and the removing either the phillips, 1/4" or Torx screws around the lip under the glass. Pull off the knobs and the glass will s-l-o-w-l-y come up with even steady lifting force. Where gloves in case it breaks but it shouldn't as long as you don't drop in on a corner
Posted on Dec 16, 2008
  • Expert Brian Dec 17, 2008
    Pull the cooktop up and out after reconnecting the gas. Then spay a soap solution on every joint, connection, and gas valve bodies and stems and look for bubbles. When you find the bubbles you have found the leak and then will know what action you need to take. It could also be under the top where the regulator connects. Soap down everything! Remember natural gas is lighter than air so it will rise above where it is actually coming from. Look for any connection that the installer used pipe dope on. Those are nortorious for leaking. Seal pipe thred connectors with yellow teflon tape. Make sure it's yellow not white tape. White is for air and water not combustible gases.
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this......
I read it and it's on replacing but the top comes out.
Gloves are a good idea too. Cut power at the breaker.
unless easy access to the wiring/plug.
Hope this helps you.
Have a good evening.
Feb 02, 2018 | KitchenAid KGCC566RBL - 5 Burners...
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
Porcelain grate scratched or stained?
If you keep using the range without the aluminum pans it will eventually go away, but aluminum will leave marks on the surface of the grate.
Aug 20, 2017 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
I can not separate the glass cooktop from the granite surface.
alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Cleaning glass cooktop surface
I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
GE 30 in.Profile JGP940 Gas Cooktop Logo
546 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
