Question about Whirlpool LER4634J Electric Dryer
Thermal fuse blown twice, what could be problem?
  • 334 Answers
Clogged vent, or filter/compartment
Posted on Dec 13, 2008
I have blown the thermal cutoff fuse twice. I bypassed the fuse and it works perfectly, for days. Were do I start looking for the main problem?
by passing the fuse is not a good idea. its more than likely the heater element is the problem.or the fan is not able to work correctly due to blockage or warn motor. over heating is the reason for the thermal switch cut off.
Feb 22, 2018 | Dryers
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
Thermal fuse blown twice.. what to check next
You might want to check on the thermostat. It could be allowing the machine to get too hot which would be the reason for the thermal fuses blowing. You do not mention the make of machine, but see your appliance parts supplier and find out from him if the thermostat is adjustable or if you need to replace a fixed temperature one.
May 26, 2011 | KitchenAid Dishwashers
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Duet dryer doesn't run. control panel lights up. push on button and all you hear is a click. what do i do?
No dryer function works when the motor cannot run and the common issue is a blown thermal fuse located on the blower housing and wired in series with the motor. There will be no power to the motor when the thermal fuse blows and the motor cannot therefore run. Bypass the thermal fuse and if the motor runs, the thermal use is indeed blown and needs to be replaced. Do not use the dryer with the thermal fuse blown due to fire hazards.
Disconnect power then open the dryer door and remove the lint filter. Remove the screws from the toe panel and remove the panel. Remove the screws securing the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them. Once done, plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced if the dryer runs. The thermal fuse is part number 3390719. Reassemble the dryer in reverse order of the disassembly steps.
Oct 10, 2010 | Whirlpool Dryers
Thermal Fuse Blows
This is usually caused by a clog in the venting. If your vent is clear I would replace the cycling thermostat for a free video on checking these components go to www.appliancehelponline.com/servicemanual.html
The cycling thermostat tells the dryer when it has reached it's high and low temperatures.
Hope this helps
Mar 21, 2010 | Whirlpool Dryers
It is a gas dryer and I have had a tech out twice to replace a part to make it heat up and now it is doing the same thime again (not heating up).
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. If you have poor or no airflow this is why your thermal fuse has blown out. Poor venting of dryer causes overheating and therefore blowes the thermal fuse. I Hope I have helped you, Tim.
Jun 05, 2009 | Kenmore Dryers
Blown thermal fuse on Kenmore dryer
I need the serial# to assist you better.
Thank you for trust fixya.com
May 14, 2009 | Dryers
Thermal fuse has blown 2 times
Check for a bad ground wire. Also while you are check the ground check all the other wires to make sure that they are seated properly and nothing has come lose or te wire plastic has come off or rubbed off and grounding itself out
Feb 21, 2009 | Dishwashers
The thermal fuse
Check yo see if you have any air restrictions by feeling the vent that exits the house. You should have strong air flow. Any restriction, even if small will cause the dryer to overheat and blow the fuse. Thanks Dave www.washermd.com
Dec 13, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
