2005 Honda Accord Logo
Posted on Jul 24, 2012
Air conditioner when the air conditioner is on it only blows hot air
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jul 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
1817
Points
47
Check whether the warm air isn't going in with the cold air .Coolant line that runs into the firewall on the passenger side of the engine which is toward the bottom half of the firewall on the passenger side. If there is warm air going into the vents with the cold air then it blows warm air. You may have to shut it manually because it gets stuck sometime. Check it out.
2 Related Answers
Anonymous
  • Posted on Sep 10, 2009
SOURCE: 2001 honda civic- air conditioner blowing hot air, emergency brake light stays on & door locks stopped working
faulty multiplex fuse box $200 dealer
Anonymous
  • Posted on Apr 16, 2011
SOURCE: 92 honda accord blows hot
I just filled my a/c and it does the exact same thing as urs. It's a 92 ex
Why does my BMW X3 blow hot air when air conditioner is on?
Its probably just low on refrigerant. I think you can borrow the guages from Autozone for free. I'd start there anyways
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
2helpful
The air conditioner starts blowing hot air on the driver side while the passenger side blows cold air.
2004 Suburban air conditioner blows hot air to the dirver side but cold air to the passenger. This does not happen all the time but has occurred several times this last summer.
Air conditioner wont work
You need to check your freon level. Go to your auto parts store and pick up a can of freon with a gauge and follow the directions on the can.
1helpful
2answers
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
After boost air conditioner started blowing hot air
BLOWING HOT AIR YOU MAY HAVE A RESTRICTION ON THE SYSTEM, OR MAYBE A REAL BAD LEAK THAT UR FREEON IS ALL GONE,
Air conditioner blows hot air, checked coolant and it is full
There are a few different possibilities for a vehicle doing this. A low refridgerant level can, or a temp control on the dash is not operating properly.
Air conditioner blows hot cold and sometimes not at all why?
hello,seem you need to send your car to authorized dealer to scan the problem,maybe the solution is only synchronizing all the flap,ty
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
