Question about ATI RADEON 9600 Pro, (256 MB) AGP Graphic Card
Radeon 9600 pro cannot install drivers
I've done lots of search and did some changes that were supposed to work: -Updated motherboard chipset(Via Chipset AMD Athlon MP) -Installed microsoft .net workframe -Uninstall all drivers using Driver Cleaner -Downloaded Ati latest driver version -Firewall is turned off Also the computer does'nt boot properly it skips the first page and I can't enter Bios because of that.
  • 30 Answers
Well, the easiest solution would be to format your computer and reinstall your OS. Though I do not think that there is something wrong with your CPU. Can you describe the problem more precisely? For example step by step, what you do first and last.
Posted on Apr 11, 2007
  • 100 Answers
Seems like you have a CPU/BIOS problem, try to get support for the manufacture of your CPU/AMD! if nothing wrong with them, it might be a maleware/virus, they sometimes do that! if nothing helps, I think that your best solution is to format, or get another CPU. :| sry.
Posted on Mar 13, 2007
2 Suggested Answers
SOURCE:
Actaviosan
  • 100 Answers
SOURCE: Radeon 9600 Pro agp 8x install problem
Havent you posted this already sir?
How to run windows 7 with ah3450 grafic card on kod p4x266 motherboard?
The MSI PM8m-V Motherboard has the Via P4M800 and Via VT8237 chipsets.
The website for MSI Does not list any drivers for Windows 7 for your motherboard. But since this is a common Via chipset you should be in luck.
A lot of driver support for VIA chips is built into Microsoft® Windows® 7 (32- and 64-bit).
VIA Hyperion Pro drivers
The VIA Hyperion Pro drivers contain all of the main platform drivers for VIA chipsets. The current release of these drivers is included in Windows 7, so at this time there is no need for a VIA Hyperion Pro package that supports Windows 7. However, as updates occur, a package will be released when needed.
You shouldn't need them, but to download the VIA Hyperion PRO Drivers click on the following link:
http://www.viaarena.com/Driver/VIA_HyperionPro_V524A.zip
The drivers for your video card the ASUS AH3450/HTP/256M Radeon HD 3450 AGP Card can be found here:
http://www.asus.com/Graphics_Cards/AGP_A_series/AH3450DI512MD2LP/#download
If you still need further drivers for this motherboard you can go to here:
http://www.via.com.tw/en/support/drivers.jsp
If you still have not found the drivers you need you can go to the MSI website and see if any of the Vista drivers will work for your system.
http://us.msi.com/product/mb/PM8M-V.html#/?div=Driver&os=Vista%2064
Aug 03, 2011 | MSI PM8M-V Motherboard
Enable AGP 4x
you don't need to reinstall or format c:\ ..all you need uninstall al the drivers and install the correct driver of your VGA add on card.
Jan 18, 2008 | ASUS VIA 694XDP Dual Processor Chipset...
For
I have not been able to add any AGP card to my PC.
My PC is a cube PC so I have been trying to install a "low end" AGP video card without a separate power connector. My only really requires are DirectX 9.x support and a minimum of 128MB (and no power connector)
The card I am currently trying to install is a Gigabyte ATI Radeon 9600Pro with 256MB.
I have also tried a ATI Radeon 9550 with 256MB and a Nvidia card
I have done all of the usual things, such as disabling onboard graphics, removing old video drivers, verified latest chipset drivers are installed, I reviewed the graphic adapter and don't see any conflicts etc.
I wonder if any of the cards I am trying to install will work with my AGP slot.
The manual for this Gigabyte card states "AGP 3.0 Slot or greater is required"
Unfortunately, this requirement wasn't on the Gigabyte or NewEgg web sites or the back of the box. Only in the install manual.
My Motherboard manual states "AGP 1.5v Card is required".
I got great AGP information from www.playtool.com. I used some of the tools suggested there such as Sandra Lite and other tools to try to determine what version my AGP Slot is. These tools don't seem to clearly state what
My PC is a Small Form Factor PC with 220W Power Supply.
It has integrated Intel Extreme Graphics
gBox P4 Blue CF-986L
Motherboard is a CFI-968L with last bios released (1.04)
www.american-media.com
Pentium 4 3.06Ghz
1G RAM
80G HD
Chipset is Intel 845GE
Windows XP Home
This is a awesome PC and I really would like to extend the life of it my adding any AGP card that supports DirectX 9.x
Read more: Adding ATI Radeon 9600Pro - AGP Slot Issue? - Tech Support Forum http://www.techsupportforum.com/forums/f24/adding-ati-radeon-9600pro-agp-slot-issue-128485.html#ixzz1FKivifx5
Feb 28, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
I have a gecube hd radeon 3850 oc addition and it keeps crashing to blue screen
Try installing new graphics drivers or reinstalling your previous drivers if you have recently updated your drivers.
Hope this helps!!
Please rate!!!
Jan 03, 2010 | GeCube RADEON 9600 Pro, (128 MB) AGP...
VIA KT400 Chipset Driver update fried my ATI Radeon 9550 AGP Card
AGP is a bit old for win7, i'd drop it. that said, if the ati card is an addin perhaps your onboard (via) chip is causing the problem. turn it off in your bios so that the install never even detects it and use drivers from ati.
Jun 09, 2009 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
Comp will not recognize my agp radeon HD2400 pro graphics card
Try the following : Go into the setup routine using the onboard video. Go to the  Intergrated Peripherals.
Find the onboard video and change it to disable. Save changes.
Change monitor to the AGP card.
  I hope this helps.
Here is a web site for your Award Bios setup:
http://www.buildeasypc.com/sw/bios_setup.htm
Inegrated Peripherals
This menu allows you to change the various I/O devices such as IDE controllers, serial ports, parallel port, keyboard etc. You can make changes as necessary. See figure 5.
Dec 19, 2008 | Biostar P4M80-M4 Motherboard
Cant install powercolor 9600 pro on ECS 845gv-m3 mobo
Appreciate the direct "Ask Me".
Background info, a Powercooler 9600 PRO EZ was most probably manufactured by C.P.Technology in Taiwan. I am sorry to say that quality wise, this company is rather low and to my understanding, a lot of their products has to be returned/replaced even new. On the other hand, the old Nvidia MX4000 might have been manufactured by Palit, also in Taiwan but has a better quality control as of the time of production. The MX4000 though only uses 128Mb of memory but runs them at 275/400 (DDR) MHz clock speed compared to the 9600 PRO 200 (400) MHz. The slow memory onto the PowerColor RADEON 9600 PRO EZ 256MB had a really bad effect on its performance.
To your concern, the ECS 845GV-M3 (V1.0) uses AGP Express but should not cause a problem to either the 256 or 128. since it is working with the 128, then it would be safe to say that the 256 is defective. if the 256 will test OK in another motherboard, then it would be a compatibility issue, try setting the CMOS/BIOS to default and see if it will work.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 17, 2008 | Computers & Internet
Video incompatibility?
The driver & Catalyst Control Center for the ATI Radeon 9600 Series is listed below for Win XP home & Pro. Lasted updated Jan-16-2008.
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/gamesite/8-1_xp32_dd_ccc_wdm_enu_57717.exe
Your install will run better if you remove previous software versions for the Radeon 9600. If your attempt to remove old software fails. ownload & run ATI's cat-uninstaller.exe found here.:
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=1447
Jan 20, 2008 | Intel Motherboard
Problem Open Gl
You will have to re-install the drivers a few times before the control panel realises there is an ATI plugged in. Once done, Direct-X will respond to the ATI drivers, and therefore work. Sorted! Good luck!
Aug 24, 2007 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
ATI RADEON 9600 Pro, (256 MB) AGP Graphic Card Logo
376 people viewed this question
Top ATI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Argospete
Argospete
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
