Question about Bamix Deluxe Handheld Blender
Instruction manual for the bamix immersion blender
I want to make mayonnaise with my bamix immersion blender but do not have the instruction manual. Which blade do I use for mayo... the solid flat one or the flat one with holes? Can the complete manual be downloaded? Thank you so much.     semajrn
  • 1 more comment
  • Anonymous Mar 15, 2014
    A plastic disk has dropped down above the blade.
    how much $ is the outer chrome stem assembly for the Bamix Gastro 200 Stick Blender 2005-2009 model going to cost me?
  • Anonymous Mar 17, 2014
    Cleaning
    Filmmaker:
    Uploaded 5 video answers.
  • 131 Answers
I've listed a vintage 1986 Bamix owner's manual/recipe booklet for sale on Etsy, along with other vintage Bamix replacement parts. http://www.etsy.com/shop/lauraslastditch
Posted on Jul 15, 2011
  • 3 Answers
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Posted on Dec 22, 2008
  • JBalbilla Nov 14, 2010
    Sorry, but the Bamix recipe for mayonnaise is useless. Made 3 attempts today and none of them worked in as many hours. Made it by hand instead in 30 minutes. Don't buy a Bamix for making mayonnaise - utter waste of money .
  • Jacob Grzywinski
    Jacob Grzywinski Jul 16, 2014
    My comclusion after numerous experoments. Bamix is not a tool for making mayoonaise. Probably speed is too high.
WHY WON'T COLD SKIMMED MILK THICKEN WITH BAMIX BLENDER `/
Skim milk has little to no fat, therefore it will not thicken when whipping. If you want to whip it, I suggest you dissolve a packet of unflavored gelatin in 1/4 oz skim milk, microwave it for about 30 seconds until the gelatin is dissolved, and add 2-3/4 cups cold skim milk. Refrigerate for about 15 minutes or until the consistency of egg whites, then try whipping it. Good luck!
May 08, 2015 | Bamix Immersion Handheld Blender
I can't get the attachments to go on the immersion blender
You did not identify your specific model; however the manual typically has illustrated instructions on how to assemble.
You may be able to find the manual for your blender here:
http://www.wpcookware.com/manuals.asp
Dec 07, 2012 | Wolfgang Puck Immersion Blender
How can i get another instruction book and recipe book. I lost both of them in a move.
It's easy! Just search for Bamix Immersion Handheld Blender under google shopping lowest price there are many avail. Also you could try contacting the company. Or you can do a search for the manual online, I looked and didn't see it, but I'm sure it's online somewhere! Alternatively you can steal them out of a box in a store. Good Luck!
Mar 15, 2011 | Bamix Immersion Handheld Blender
My mayonnaise won't work it is just runny
I believe the issue is more with the method of preparation. Try slowly adding the oil when preparation the mayo and that should alleviate the problem.
Good luck and Happy Eating,
Alex
Mar 12, 2011 | Bamix Deluxe Handheld Blender
I have a Bamix Immersion Blender, but it stopped working. Press it on and it makes a humming sound but does not move. Where (in Canada) can it be repaired or replaced?
Sounds like the motor shaft has broken from the impeller. If I had it I would crack the case and see if that were true.(You might see screws holding the case together- If not, they might be hidden under the cosmetic label. If it is true, you need factory help. You better call Customer Service for Bamix.
THis is from http://www.bamix-usa.com/:
The drive shaft is frozen i.e. no longer rotates although the motor still hums: place the operative part of the appliance for 5 to 10 minutes in a jug of hot water, then switch it on. In general the appliance will then work again - if not just try to free the shaft very carefully with pliers
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers Processor/Dry Grinder: Discoloration of the bowl (i.e. carrots) can be cleaned with a cloth impregnated with salad oil.
Oct 23, 2009 | Bamix Immersion Handheld Blender
The motor on the Bamix hand mixer is working properly yet the spindle will not spin. It appears as if it is not engaging. The spindle is not jammed.
there is a rubber connetion between the motor spline and the spindle which holds the screw that connects to the spindle, this has broken
Jun 09, 2009 | Bamix Immersion Handheld Blender
Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Mar 13, 2009 | Blenders
Bamix Deluxe Handheld Blender Logo
2,675 people viewed this question
Top Bamix Blenders Experts
Ruth summersides
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
