Question about SanDisk Sansa e200 MP3 Player
No connector port on e200
On my e200 sansa there is a battery compartment where the port connector should be i dont see any port connector on it.
I found the port connector under the battery case which was attached to a case that the ipod was in
Posted on Dec 14, 2008
Hello i'm venkat.. i have a problem in my sansa 8gb ipod ..its got shut down due to low battery and when i was recharging it, it's not getting on.... could u please tell me the address where it can be...
You could send in the Sansa E280 to here: http://www.pdasmart.com/pda-battery-center/battery_SANDISK_SanDisk-Sansa-e280_battery_center.htm
They will replace your battery for you.
You could also purchase the battery here: http://www.amazon.com/Sandisk-Sansa-Battery-E200-E250/dp/B003E4WL6K and install it yourself.
How do I replace the battery on the Sansa e200 player?
1. Remove the back on the e200 by removing the 4 screws.
2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove. NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player.
3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player.
4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place.
5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable.
6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device. NOTE: If the device goes directly to a black screen after unplugging it, then the battery has been replaced incorrectly. Take the back off the player once again and flip the battery around and the e200 device should work properly.
Mar 09, 2011 | SanDisk Sansa E280 MP3 Player
Battery wont recharge-
Below are some things to check for when charging your Sansa player:
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
To Remove the Battery... 1. Remove the back on the e200 by removing the 4 screws. 2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove. NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player. 3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player. 4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place. 5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable. 6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device.
May 31, 2010 | SanDisk Sansa e250 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Sansa 40gb e260 dont know how to put music on it . dont have manuel
For the Sansa e260 4 GB there are 2 versions for the e200 series players:
version 1 manual
version 2 manual
Check the version of your Sansa e200 series:
go to Settings > Info.
SD card compatibility:
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Dec 09, 2009 | SanDisk Sansa e260 MP3 Player
Sansa won't turn on after using an ipod "road trip" fm transmitter
Kinda the same thing happened to me. I tried to plug my sansa into my friends iHome and it blew out one of his speakers and screwed up my sansa, which was an e270.
Aug 28, 2008 | SanDisk Sansa e200 MP3 Player
Sansa E200 Problems
try taking the battery out of it.
Mar 23, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e 200
my sansa e200 is having some problems the ring is lite up but the screen is black i tryed alot of things nothing is really working can you please HELPPPPPP me pleaseeee
Feb 21, 2008 | SanDisk Sansa e200 MP3 Player
My computer doesn't recognize my Sansa E200
Make sure player's usb menu is set to MSC, so computer will recognize it. Not sure why, but sometimes it helps to try another usb port on the computer. Good luck.
Dec 29, 2007 | SanDisk Sansa e200 MP3 Player
Sansa E200
You may have uploaded the incorrect or have had unstable power connected to your Sansa E200 when updating. If that is so, your Sansa E200 has been bricked and it's useless. This is the correct Sansa E200 Firmware Updater, "http://www.sandisk.com/Retail/Default.aspx?CatID=1376" (Note: Sandisk is Sansa)
Aug 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
