Dvd player won't read the dvd and displaying'no disc' Ihave a second hand satellite Pro Laptop whichhas a CD/DVD drive which reads CDs but not DVDs. I suspect that the Windows XP Home is a later install because some of the Toshiba features are not present. When I was researching new drives I read somewhere that you had to set something or it would not read DVDs. Thought I would be clever and bought a USB drive which worked when first connected,but now has the same fault
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Posted on Dec 13, 2008
L755-s5311 dvd not reading dvds or cds,
Your choices are to replace the drive or purchase an external DVD drive.
DVD/CD drives do eventually go bad.
Feb 05, 2014 | Toshiba Satellite Laptop Coretm Intel...
Dvd drive cant read dvds but can read vcds
First of all, are you trying to read Blu-Ray DVDs? Unless your drive is made for them, it won't be able to. The same may be true if you're trying to read a dual-layer DVD. Not all DVD drives can handle them.
CDs and DVDs need different kinds of laser light to be read, and a combo drive like yours is essentially two drives in one. Sometimes a problem develops in the pickup and it can read one kind of disc and not the other. My experience is that it's usually the DVD function that fails more often. The data on a DVD is much more densely packed and harder to read.
Try making sure the discs you're trying to read are clean. If the problem is affecting all the DVDs you try, replace the drive. New drives for a desktop computer only cost around $20 to $30 and they are easy to change. In a laptop, the drive will be more expensive and maybe hard to find; in that case you may want to consider a USB external burner as a replacement. This is also an option for desktops as well.
May 20, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
My laptop wont read cds or dvds
Check with a bootable OS disc.
If it reads then repair the os
If the same issue is there, go for the replacement of Optical drive
Aug 27, 2009 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
Dvd ram can not read cd.
I had the same problem, this is what worked for me.... I opened the cd/dvd drive on the side of my laptop and gently cleaned the small laser and hey presto it worked, can now erase,read and play my discs.Give this a try it only takes a few seconds. Good Luck
Apr 20, 2009 | Acer Aspire 4315 Notebook
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Mar 21, 2009 | Compaq Presario C700T Notebook
DVD drive reads DVDs but not CDs
Sep 28, 2008 | Computers & Internet
Pioneer DVR-111D doesn't read CDs/DVDs, discs don't even spin
I've deviced DVD-RW drive but not display with my computer. tell m..
Apr 21, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Jan 22, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
