Question about Electrical Supplies
3 ways not wired correctly
I have a leviton 3-way light switch where there are two switches on one unit.
I have two different lights working from this unit: an entry way light and a stairway light.
The entry way light is worked from the bottom toggle along with another hallway switch from a separate unit. The stairway light is working from this same double stacked three way, top toggle and another three way upstairs.
I took the old switch out, not sure what it was, and replaced it with this leviton. I wired it exactly the way the old switch was wired.
I have two whites that I put on the right side, dark screws, two reds that I put on the left side, screw 1& 4 and 2 blaks that I also put on the left side, screw 2 & 3.
And a ground on the green screw.
Now depending on how the individual hallway and stairway switches are turned on determines which light the double toggle turns on. Sometimes the bottom switch turns on the center hallway litght and sometimes it turns on the stairway light.
I threw out the directions because I thought it was a no brainer... Probaly for you, not for me.
Any help will be appreciate.
  • 413 Answers
Im not sure if you know what you got yourself into but i hope this helps. Sorry for all the words but this does take some reading if this is new to you.
Posted on Dec 19, 2008
Fan speed control on 2 way circuit
1) Guessing you have 3-way switch where 2 different switches control same Load (light, fan, motor). Unknown wiring, and unknown if fan and light are wired separately.
2) Google search for 3-way fan switch shows Leviton IPF05 with simple straight-forward wiring. Link below has instruction manual, and Live chat button located to right of LEVITON
3) It appears that the Leviton device must replace Line side switch.
4) Uncertain if this device also controls fan since the wiring is so simple.
Feb 22, 2013 | AMS Lutron SFSQ-F-HO Skylark Single-Pole...
Dimmer does not work
A 3-way light switch needs 3 wires for both switches to work correctly. If there is only 2 wires on the switch, its not a 3-way. Only two black wires on the switch means it can be wired either way. The power and light leads are inter changeable. If you really need a 3-way switch, be sure it is labeled as that on the box and look for 3 connections on the switch its self. Else, try a switch rated for a higher amperage.
Nov 30, 2011 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
Where on line is there a wiring diagram for the Leviton GLW-1463? I could'nt seem to find it on there web-site. Thank you. :)
Leviton GLW-1463 appears to be ordinary lighted 3-way toggle switch.
This switch is used in a hallway application where more than 1 switch controls a light.
The green screw is for bare ground wire.
There are two brass colored screws for traveler wires, and 1 dark screw for common wire.
If you are replacing another 3-way switch, then note color of each screw on old switch.
Put wire from old dark screw to new dark screw.
The travelers wires can go onto either brass screw.
Open following link for drawing of ordinary 3-way and 4-way circuits
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Leviton 3W Lighted Toggle Switch -...
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
Upvote the help.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
Cannot get the decora 4 way light switch to work - 2 of the 3 switches work but cannot get the 3rd to work. Replacing regular toggle switches which all worked but wiring different for decora switches.
Decora 3-way and 4-way switches do not wire differently than toggle-type switches.
Instructions below are tedious but will accurately guide you to solution.
Let's break down the problem starting with 3-ways.
1) Start with 3-way switches:
Old 3-way switch has 2 brass screws and 1 dark screw
New decora has same color screws.
Wire that went to dark screw on old device must attach to dark screw on decora device.
Other two wires can attach to either brass screw.
Wires that attach to brass screws are travelers ... these wires travel to the 4-way switch.
So there are 2 traveler wires at each 3-way switch.
2) Let's test if 3-way switches are wired correctly by taking 4-way switch out of equation.
We will resolve problem with 4-way switch after 3-ways are correct.
There are 4 wires at the 4-way switch.
These are the 2 traveler wires that arrive from each 3-way switch.
At the 4-way switch, 2 wires arrive in one cable, and 2 wires arrive from another cable.
To say it differently, there are 2 wires from cable1 and 2 wires from cable2.
Connect 1 wire from cable1 to 1 wire from cable2 with a wire nut
Now connect the 2nd wire from cable1 to 2nd wire from cable2 with another wire nut.
So now the traveler wires are connected, and the 4 way switch is out of equation.
Turn on power, and click 3-way switches to see if both switches turn lights on-off in all positions.
Do your 3-way switches work correctly?
3) If 3-ways are not correct, then you have wrong wire connected to dark screw.
First thing to check is if you can identify traveler wire colors by looking at wires at 4-way switch.
Remember, traveler wires at 4-way switch go back to 3-way switch and connect to brass screws on 3-way switch.
4) If you cannot tell traveler wires by looking at 4-way switch, then you can try different combinations until both 3-way switches work.
Or you can test: disconnect wires from one of the 3-way switches. Separate 3 wires for testing. Move other 3-way switch to down position. Turn on power. Test each wire to bare ground wire. Mark wire that lights up. Now move other 3-way to up position. Test each wire to bare ground wire. If same wire lights up each test, then that wire goes to dark screw. If different wire lights up, then mark that wire. The two marked wires are travelers, and they connect to brass screws. Other wire connects to dark screw. Repeat identical test for other 3-way switch.
At this point your 3-way switches will work, if light bubs are not burned out.
5) Last step, the 4 way switch.
Remember from step above, that 2 wires arrive in cable1: These 2 wires connect on one side of 4-way switch. The other 2 wires that arrive in cable2 connect of other side of 4-way switch.
Add a comment if you need more help.
Dec 23, 2010 | Leviton Decora Light Dimmer Switch
I installed the motion sensor on a 3way switch. Connected the red lead to the common and the yellow w/red strip lead to a traveler and the black lead to the other traveler. No matter how i switch the...
Leviton manuals:
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Nov 23, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
How does the illuminated light work inside a Leviton light switch? Since there is no neutral (white) wire hooked up to the switch itself? Does the switch illumination light have its current flow into the...
The neon lamp inside of the switch draws very little current (milli, or mico amps) so there is no significant current flowing to ground.
As for your real question, there are several various types of 3-way pilot switches:
Load on: Pilot on
Load off: Pilot on
Some 3-way pilot switches have an external lead which allows them to be configured either way.
If both of your switches are the same type and are wired correctly, they should work the same.
If you suspect that one is defective, try swapping them.
Aug 03, 2009 | Electrical Supplies
Electrical Supplies Logo
328 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
