Question about Texas Instruments TI-83 Plus Calculator
Turns on but does not respond to buttons
I have tried clearing the memory it does not work. Problem: Calculator turns on fine. It does not respond to ANY buttons pushed. Help?
  • mrazmeh Dec 05, 2007
    I have the same problem. I can push buttons for a long time until it responds and I can only turn it off by taking out the regular batteries and then it saus ram cleared the next time I turn it on.
Replacing usual batteries will work, but removing the "watch" battery will clear all your RAM, so avoid it. Despite all that, i still can't connect the calculator to my computer via the USB cable, so it might have some undesirable after effects. I guess the hardware is a bit of a pushover, thank god I could fix the problem before my major maths test.
Posted on Sep 08, 2007
  • 35 Answers
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem. If not, contact the guys over at Texas Instruments for replacement parts if you need them.
Posted on Aug 27, 2007
What do calculator buttons on Staples calculators stand for ? In particular, 0N/C, %, +/t, MC, MR, M+, M-, --> I received this giant calculator as a X-mas present (2010) I really...
Not sure what they all mean but
ON/C turns calculator on or Cancels the current entry % divides by 100 or percent MC - memory clear M+ add to what is stored in memory M- subtract from what is in memory
You can get a manual at http://www.product-support-staples.com/DisplaySKU.aspx?SKU=600516
If this was useful please give me a thumbs up
Mar 20, 2011 | Staples SPLP500 Scientific Calculator
Somehow I have pushed a button I wasn't supposed to. When I turn the calculator on there is an 'M' on the screen. I cannot remove it. This makes my totals show up with out the cents column.
There is a couple things we can try, press the clear button on the calculator, failing that! remove the batteries for at least 60 seconds to see if it will clear "M stands for memory" the only other thing you can do is locate the M key, press once engages the memory, press again turns it off on some models.
Mar 13, 2011 | Canon P1-DHV Calculator
What do the following keys signify? Or do? GT MU MRC AC, CE ON/C 00 +/-
Hi, here are some of the answers to your questions.
GT:- Grand Total: It shows the cumulative total of your calculations
MU:- Mark Up: It is used to calculate the CROSS PROFIT MARGIN in business environment.
MRC:- If pressed once, it shows the number stored in the memory. If pressed twice it clears the memory.
AC:- All Clear: It clears everything
CE:- Clear Entry: Clears the last entry of calculations.
ON/C: If the calculator is off, it turns it on. If the calculator is on it clears all entries.
If you have any more questions you can visit this site: http://www.aurora-ltd.co.uk/OpInst/FunctionsGuide.htm it has almost everything covering the calculator buttons.
Lujaina96
Feb 12, 2011 | Office Equipment & Supplies
My ti-84 plus it does not respond to the function + or - OR other function, & it come up to display very slow ,slow. thanks
Hi xvbanh,
You need to free up some memory. Try clearing your RAM. Your calculator should operate properly afterward.
Go to [2nd] [MEM] [7] [1] [2]
If your calculator still won't let you delete the RAM memory try the procedure below.
Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
reinsert the AAA battery and then turn the calculator on. The calculator should display the
message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
Jan 06, 2011 | Texas Instruments TI-84 Plus Silver...
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
My TI-89 calculator turns on, but gets stuck on window editor
If you're willing to have all RAM cleared, try a hard reset.
Press and hold the 2ND, Left-arrow, and Right-arrow keys.
Press and release the ON key.
Feb 20, 2010 | Texas Instruments TI-89 Calculator
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
TI-84 plus Silver edition resets when connected to PC
I had that same problem.
the blinking black box on my calculator would stay on.
every time I turned on my calculator, it would say 'ram cleared'
if I held down a button for 2 seconds or so, it would finally respond
SOLUTION:
blow really hard into the I/O port. It fixed it for me!
Sep 17, 2008 | Texas Instruments TI-84 Plus Calculator
TI-89
Did you try [left][right][2nd][on]? It reinitializes the memory and clears the ram.
Dec 10, 2006 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
340 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
