Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cooling properly
I have a GE GSS25WGPABB. The freezer door was left open a crack for 24 hrs and the top shelf thawed bottom shelf was still frozen. Cleaned ice offf door and closed. Freezer will not cool beloe 20 deg. now. I believe the evap fan is inop. or the temp sensor for the fan are bad. What is the resistance I should be checking for on the temp sensors and the evap fan. Both are reading open?
  • 1 more comment
  • footeone Dec 13, 2008
    need resistance range for testing the evap fan and temp sensor for evap fan
    anyone out there actually reading my question
  • 10,594 Answers
Fan resistance range can be 100 ohms to 200 ohms.
Regarding temp sensor, it would be thermostat switch and clicked on low temp and switched Off on bit high temp.
Posted on Dec 13, 2008
  • 10,515 Answers
It should be greater than 15 K ohms ...
Thanks.
  • taran_2005
    taran_2005 Dec 13, 2008
    Electrical specifications:
    Power supply Voltage : 110 VAC/50Hz
    Voltage operating range : 90 to 140VAC
    Operating Temperature : -25�C to +85�C
    Relay output contact capacity : 16 Amps at 127 VAC (Inductive load)
    Sensor specification:
    Temperature sensor : NTC Thermistor (10K)
    Beta Value : 3977+/- 1% at 25/85�C
    Response time : > 20 seconds
    Operating Temperature : -40�C to + 85�C
    Insulation resistance : > 100 Mega ohms at 500VDC
  • 4,806 Answers
Have you re-adjusted the temperature control settings at all?
  • Lee Hodgson
    Lee Hodgson Dec 13, 2008
    there seems to be no schematics available for this refridgerator:
    you can contact customer support here:
    http://genet.geappliances.com/DocSearch/...
    regards
  • 334 Answers
The thermostat sensor is probably located in the top section right?
If so, it is reading the top temp and thinks it is cold enough.
Get a coolere full of ice. store your frozen goods there. unplug the fridge.
open all the freezer doors.
Make sure any ice is thowed out and nothing is obstructing the fan.
(The condensation could have frozen up to constrict the fan as well)
Plug it back up and turn the Tstat down, make sure the fan is operating, let it go for an hour or so and check the temp in both compartments.
  • 275 Answers
Hello footeone , Is the motor running" ?
Make sure the compressor is running and not just a fan motor.
Unplug it for 30 mins then it back in. Listen for the compressor to start running, if you hear a clicking noise and the compressor never starts running then the relay needs to be replaced. If the compressor is in fact running and it will not cool then you may be low on coolant.
    Genius:
  • 3,422 Answers
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
  • Priya darshan Dec 13, 2008
    If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The
    compressor is a football-sized case with no apparent moving parts. It's
    on the outside of the refrigerator at the back near the bottom. If it
    is humming or making a continuous noise and your refrigerator is still
    not cooling, there may be a more serious problem with one or more of
    several different components, we recommend contacting a qualified
    appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
    Genius:
  • 3,422 Answers
  • The defrost timer
    Top Expert:
  • GE Master
  • 78,267 Answers
U MAY HAVE JUST OVERHEATED THE COMPRESSOR MODULE, LET IT COOL, TURN IT OFF BY DISCONNECTING THE POWER, THEN AFTER 5 MIN'S SWITCH BACK ON AND SEE WHAT HAPPENS.
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
My GE Refrigerator doesn't work properly.
The two main causes for your problem is the control set wrong and the second one isthe defrost element has burned out... Sometime the defrost clock will go out as well.... always try to set your controls to midrange and if the bottom of the freezer compartment is cold and frosty but the refrigerator is cold ... Remove all the food and store in a backup refrigerator you can rent from an appliance rental center... Unplug your refrigerator and let it defrost for 48 hours.... In the mean time open up the doors and clean it from top to bottom. place a fresh opened box of arm and hammer baking soda in the frige side and one in the freezer side. Plug back in after completely deftosted and place a small plastic cup half filled with water on each shelf of the freezer. Close the doors and wait 8 hours... Open the freezer and check the plastic cups.... if they are all frozen great..now wait for 3 days do the test again if the bottom cup is frozen and the top shelf is not ... its time for a new defrost element or a defrost timer.
25 years service
stocktongoodrepair@gmail.com
Sep 21, 2014 | GE Refrigerators
Water won't dispense
Your water line may be frozen through the freezer door. Remove the kickpanel at the bottom and you will see a quick disconnect. remove it and shut the freezer door and call for water. if you have water to that point then you know the line is frozen. Only fix is to replace the door or let the ref thaw for 24 hrs. Hope this helps. MJ
May 30, 2010 | GE CleanSteel GSL25JFTBS
Fridigaire top freezer has stopped cooling
It could be frosted up or the drain plugged which would cut off the air flow to refrig section. If you see any frost or ice anywhere empty the unit and let it set with doors open 24 hrs to thaw. Or take the inner panel out of the freezer to see where the blockage is. If the coil is completely frosted over you have a defrost problem and need to determine which component has failed
May 20, 2010 | Frigidaire FRT21H8 Top Freezer...
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
183 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
