Question about 3M - EVD Projection Lamp for Overhead Projectors Multimedia Projector
How do you focus in an overhead projector image? old version.
How can I focus it other than using the focus knob
The focus knob is the way you focus overhead projectors. Perhaps you simply haven't turned the knob far enough? How far is the projector from the screen? If it's quite close, you need to turn the knob to raise the lens. If far away, turn it to lower the lens.
Nov 25, 2015 | 3M 9200 Overhead Projector
Tip
Overhead Projector Tip- best results!!
For best results, slant the screen forward slightly so it meets at a 90 degree angle with the projected image light beam. In not, then a keystone effect results where the projected image is taller on top or on the sides; in other words, the projected image is a parallelogram, not a square.
on Aug 16, 2010 | Office Equipment & Supplies
Tip
Overhead Projector TIp #2
Some people switch the projector on and off to shift the focus of the audience from the image back to the speaker. This also saves the lamp. This is a matter of personal presentation style.
Elmo overhead projector
Move the projector away from the wall, the picture gets bigger. Then use the focus knob at the top to get a clear picture on the wall. Then use a camera to take a picture of the wall. Then upload the picture to the place you want to transfer it to.
Dec 20, 2013 | Elmo Projectors Elmo HP-L3550S Overhead...
When I turn on the overhead projector it displays picture on the ceiling. Need to adjust to show on the wall. Do not have a manual.
Hi! This is a pretty common problem with overhead projectors. At the top of the arm that's over the unit, there should be a lens unit. The unit needs to be rotated so that one lens points down, and one lens points towards the screen. Once the lens is rotated properly, the lens unit is moved up or down in order to focus. There's usually a knob to turn to move the lens up or down.
Oct 28, 2013 | Apollo Horizon 2 OpenHead Overhead...
Tip
Overhead Projector TIp #1
One general rule about projected image size: judge the distance between screen and farthest viewer, divide by six and use this number to figure image width.
The auto focus won't focus on images from far away, 2 feet. It only focuses at 2-3 inches
Most CMOS web-cams have a focusing ring round the lens which rotates to give you basic adjustment - after that the auto-focus should sharpen up the image
Feb 10, 2011 | Avermedia AVerVision CP155 Portable...
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
What is an Overhead Projector?
An overhead projector is a very basic but reliable form of projector. The overhead projector displays images onto a screen or wall. It consists of a large box containing cooling fan and an extremely bright light, with a long arm extended above it. At the end of the arm is a mirror that catches and redirects the light towards the screen.
An overhead projector can be used to enlarge images onto the screen or wall for audiences to view.
Aug 12, 2010 | Buhl Office Equipment & Supplies
22 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
