Question about Reddy R155D Utility Heater
I have a reddi heater Pro 150
When I plug it in it blows smoke and will not light. The fan turns and runs.
  • Anonymous Jan 16, 2009
    i have a reddy heater pro 150 that keeps shutting off and i have to push the reset button on it, why?
  • 232 Answers
You don't give the model of the heater, only the series. You must troubleshoot, first and see if the ignitor or spark plug (whichever your Pro 150 has) to see if there is spark or glow present to ignite the fuel.
Troubleshooting tips for a spark plug type heater
Troubleshooting tips for Hot surface ignitor type heater
Posted on Dec 13, 2008
I had the same problem. Fixing it is simple.. It will take you about one and a half hours to be problem free. Take the unit apart its very simple. Make sure the lines are clear and the tank filter is not blocked. Then take the pump apart not to loose and small bearing parts there should be only one under a spring. Then take the pump of the motor and clean the black dirt you will see on the pump by the motor. Make sure the sliders slide free for this is and important part of making this whole thing work . Put it back together and you should be good. There is two filters both should be cleaned and or replaced. If you don't have any then just clean them and dry them until you are able to get them. This should fix your problems and most others as well. I found this out the hard way..... Good luck
Posted on Jan 06, 2009
Reddy Heater Pro 100: plug in, fan turns on, blows out small amounts of unburned fuel and then fan shut off. What could be the problem?
jeffsampson,
This is a classic reddy heat problem. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to go to get the parts you need to fix it.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 29, 2010 | Reddy R115DT Oil Filled Utility Heater
Shuts down after about 30 seconds, blowing some smoke.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R155D Utility Heater Logo
732 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
