Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer doesn't get hot
The dryer is not getting hot
  • 2 more comments
  • ttodd24034 Dec 14, 2008
    Dryer runs but no heat on any setting.
  • gammeljoe Feb 23, 2009
    where is the thermal fuse?
  • ttodd24034 May 11, 2010
    Answer to clarification request from Shaboom99. It is electric. It was purchased new 13 months ago. Circuit breaker is not tripped. I will take it apart and check the thermal fuse and heater as suggested by
    hamm3rh3ad
    Thanks.
    Tim
  • Ray May 11, 2010
    Is this a gas or electric dryer, and how old is it? Any other information would be helpful.
    Ray
  • 85 Answers
Check these 3 things breaker could be tripped remember the outlet for dryer has 2 breakers one could be tripped and dryer could run. check thermal fuse and heater. always disconnect electrical power b4 servicing
Posted on Dec 16, 2008
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Reset dryer
there are thermal one time use fuses and your heater element may also be faulty.
here are more info of fuse locations etc.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-3--RFBHVDc1MEVDIA==/GE-Dryer-doesn-t-heat
Jun 14, 2013 | GE Profile Harmony DPGT750EC Electric...
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
My dryer doesn't want to dry clothes
is it getting hot if not maybe your heating element .There is also little sensors thru the dryer one may be bad
May 21, 2012 | Kenmore Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Dryer gets hot but doesn't dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 19, 2011 | Kenmore Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
102 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
