Question about Bamix Deluxe Handheld Blender
Hi,  I have a Bamix immersion blender and do not have the instruction manual. I want to make mayonnaise but do not know which blade to use... the flat one or the one with holes in it?
  • 276 Answers
The B blade is the one to use - the B blade is the one with the "holes" in it.
Posted on Apr 07, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Posted on Dec 22, 2008
I need attachments
It seems you can no longer buy the HA-3058 or parts for that, however Bamix sells a similar product it seems to be the same machine with only a few aesthetic changes.
They sell many accessories and you can get blades.
Check:
http://www.bamix.com/
http://www.bamix-blender.co.uk/
I have had our customers buy the Bamix blades for the MegaMix HA3058 and the blades are interchangeable on those machines.
-Colleen@ MendingShed http://www.bamix.com/ http://www.bamix-blender.co.uk/
Apr 06, 2015 | Blenders
How can i get another instruction book and recipe book. I lost both of them in a move.
It's easy! Just search for Bamix Immersion Handheld Blender under google shopping lowest price there are many avail. Also you could try contacting the company. Or you can do a search for the manual online, I looked and didn't see it, but I'm sure it's online somewhere! Alternatively you can steal them out of a box in a store. Good Luck!
Mar 15, 2011 | Bamix Immersion Handheld Blender
My mayonnaise won't work it is just runny
I believe the issue is more with the method of preparation. Try slowly adding the oil when preparation the mayo and that should alleviate the problem.
Good luck and Happy Eating,
Alex
Mar 12, 2011 | Bamix Deluxe Handheld Blender
Removable blades won't stay on. Used to be very hard to get off, but now they are loose and only one will stay on. Not sure if the (male)spinning shaft is worn down or if I just need to clamp the female...
sFirst give the female part a good clean out with hot water and floss the little slits, then squeeze it in with a pair of plyers. not too much or it'll get too tight.
Mar 07, 2011 | Bamix Immersion Handheld Blender
Shaft does not turn still vibrates
Same happened on mine. It is a M100. I pulled off the blade and guard (screws off the opposite way to normal), lifted the black rubber seal on the shaft as far out of the way as I could and cleaned it out. I then put a little WD-40 down the shaft and waited a while and twisted the shaft a little with pliers to work in the WD-40. After a few minutes it ran and fairly quickly came up to full speed.
Nov 08, 2009 | Bamix Deluxe Handheld Blender
The motor on the Bamix hand mixer is working properly yet the spindle will not spin. It appears as if it is not engaging. The spindle is not jammed.
there is a rubber connetion between the motor spline and the spindle which holds the screw that connects to the spindle, this has broken
Jun 09, 2009 | Bamix Immersion Handheld Blender
Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Mar 13, 2009 | Blenders
Instruction manual for the bamix immersion blender
go back
Dec 13, 2008 | Bamix Deluxe Handheld Blender
Bamix Deluxe Handheld Blender Logo
547 people viewed this question
Top Bamix Blenders Experts
Ruth summersides
Stan Ford
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
