Back to:
Tags:
Emerson CKS2237 Clock Radio
TIme Change (by 4 users)
posted by rracie on Mar 12, 2007
Since the time change was moved up my clock is now a hour behind, how can i fix this?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Mar 14, 2008
Since time change, my clock is 1 hour behind like the rest of the bloggers here. I changed the time, but went right back to old time before day light savings. Won't change itself until the old format of daylight saving comes into effect sometime in April 2008 This has happen the last two years.
Comment by Guest, posted on Mar 09, 2008
my clock is one hour behind with the new tieme change how can i fix it ?
Comment by joohoo, posted on Mar 09, 2008
time change was moved up my clock is now a hour behind, how can i fix this? time on clock is 7 mins. slow all the time?
Best Solution
posted on Mar 18, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi look at that site from Emerson
http://www.fox-international.com/emerson...
If your locky you have a radio on group 2 and it could be fix
Mine is to hold (2000)
Martin
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TIme Change:
I don't want to Accept this solution
Solution #2
posted on Mar 12, 2007
FixYa! (100)
Noggin
Rank:Guru Guru
Rating: 88%, 1577 votes
check this link and hopefully it will help - speak to emerson and force them into a solution - you are not alone
http://www.fixya.com/support/t137276-day...
if nothing on this link helps then check the rest of the thread by clicking on the link to dddddddddd the user at the top - there is more
Hope this helps - if not please ask again and i will try to find more specific info for your model.
Thank You!
Can you Help with these Clock Radios problems?
I lost/misplaced the instruction manual for my Emerson...
It started out fine, but now I can hardly hear it. The...
I have: SN 407030070PH Model # CKS2237 My clock...
My radio stopped displaying anything. It said low battery....
The date has fallen one day behind on my CKS2237 clock...
Loading problems.
Repair Service
Find Clock Radio Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
