Question about HP Pavilion a1620n (882780664494) PC Desktop
Fan runs loud,constant on HP a1620n
I had some startup problems about 2 weeks ago that seem to coincide with the fan problem. I took off the cover and fiddled with the hard drive connections and cleaned out some dust inside the case. The boot problem seems to be OK now, yet the fan problem persists.
Any ideas?
  • Steve D
    Steve D Dec 13, 2008
    I've cleaned the inside of the case thoroughly, including the fins on around the CPU and the problem persists. Any more ideas?
  • Anonymous Apr 18, 2009
    Exact same problem on an HP a1030n. Have cleaned it out numerous times and fan continues to run loud and constant. Annoying bigtime. Need some better help than the first barely legible reply. Ideas?
  • 112 Answers
Cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
Posted on Dec 13, 2008
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Why is it that my refrigerator does not get cold and my freezer is not making ice
SOUNDS LIKE YOU EVAPORATOR FAN HAS EITHER SEIZED----REPLACE; OR WAS BANGING ON ICE AND FINALLY STOPPED ---DEFROST
May 15, 2014 | Refrigerators
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Refrigerator not cooling...makes hissing noise
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
Dec 16, 2009 | Amana Refrigerators
I have an a1620n HP desktop and I had to recently get a new PSU. Ever since then the cpu fan is running very loud at its max speed (around 4000rpm). It is quiet when the computer boots for a few moments...
What kind of fan is it and what are the volts and the amps it makes a difference if they are not close or the same as the original/ is it plugged into the mobo or is it a tap in on the power supply's large white y/r/b/r/wires this kind is not good for the cpu fans. let me know i will help
Jul 09, 2009 | HP Pavilion a1620n (882780664494) PC...
Fan runs constantly
one reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Jun 03, 2009 | HP Pavilion a1110n (PX743AA) PC Desktop
I think the fan is making a super loud grinding noise.
I would not recommend this. You could fry your cpu and then you would have no notebook. If you are going to open the notebook make sure there is nothing interfering with the fan. The fan can be replace. Take the fan out and try to replace it, if needed. Do not run the notebook without a fan.
Feb 18, 2009 | HP Pavilion a1620n (882780664494) PC...
PC fan running loud & constant
Change fans. Fans do not have a long life.
Dec 15, 2008 | HP Pavilion a1620n (882780664494) PC...
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
Jun 02, 2008 | Heating & Cooling
HP Pavilion  a1620n (882780664494) PC Desktop Logo
438 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
