Question about Philips 60PP9352 60" Rear Projection Television
Phillips 60" Changing STK392-120 Removing board Model#60PP936H/17
The question I have is I have all of my screws out of my board and the board will move around freely. The fly back transformer which has 3 large leads and one small in the back needs to be diconnected. The set has been unplugged for about 12 hours. Do I need to remove these with insulated needle nose? I don't know how to discharge the transformer. I got lit up by one years ago trying to find a cold soder joint. This set is different it has spring clips on the IC's where they fasten to the heat sinks instead of screws and they are located more towards the middle of the board not the back like the post.
  • 2 more comments
  • mrscottydawg Dec 16, 2008
    Man this was very helpful! I have the board out and IC's removed now waiting on parts should be here tomorrow. The web site www.tvrepairkits showed my same set.
    Thank You very much!
  • mrscottydawg Dec 20, 2008
    Ordered and recieved my stk392-120 Ic's replaced both. Also removed one leg of each resistor and checked values, none of them were burned or open, none found bad. Hooked everything back up and reset convergence to factory then readjusted convergence. Still same picture all whites are greenesh color and blue convergence will not respond. This Tv is only like two years old and looks brand new on the inside, Any input would be great.
  • mrscottydawg Dec 21, 2008
    Thanks I'll try the resistors.
    Thanks
  • GARYBOKAMP2 May 11, 2010
    Which resistors do I need to replace when I replace the stk392-120's on my 60pp93-5217 rear projection? Please help. Want to replace why I have it out. Thanks, Gary
  • Philips Master
  • 3,459 Answers
Typicaly you can remove the SSB board on the left without having to remove the flyback wires. If however you are trying to remove the entire deck all at once you will need to remove the flyback wires as indicated.
You do not need to use needle nose pliers. Goto the site www.TvRepairKits.com and click on the "Tips" menu. Under that section you will see instuctions on how to remove the HVG/flyback wires.
Hope this helps,
Posted on Dec 15, 2008
  • Edward
    Edward Dec 20, 2008
    You need to replace all of the resistors even if they test ok with your meter. If you ordered a kit from www.TvRepairKits.com the resistors were included.
I have a Chevy Equinox LT with 235 60 17 tires on it.. I came across a set of 235 65 17 tires.. Can I put these on or would they affect the car/performance?
They would be fine, they will be a little bit taller then your factory tires, but you should have plenty of clearance on that model. May effect your speedometer, so pay attention to speed after changing to different tire size. Should only be a half inch difference I think, so your only talking a couple miles an hour. Easy test put cruise on 60 mph. drive 1 mile timing it should take exactly 60 seconds to reach the end of the mile.
Jun 12, 2011 | 2005 Chevrolet Equinox
How do i change the belt on the eureka 4703D
Changing the belt is quite easy on this unit.
First, you will need a phillips screwdriver looks like the X. there should be 2 screws on the top cover, and then MAYBE one more there by the hose where it attaches to the base at the back. The top cover comes off and you have full access to the belt underneath.
Also, side note, once you have the cover off there you should see a black and yellow sticker near where the belt rides, and it will go into more details to changing the belt.
Nov 03, 2010 | Eureka Power Plus 4703D Bagless Upright...
How do you change the light bulb on an electrolux built in microwave ?
It is indeed straightforward but it requires removing the 4 phillips head screws that hold the trim kit on. Then you need to remove it from the cabinet (along with unplugging the cord.) Once that is done you will need to remove the 4 black phillips head screws along the bottom part of each side, 2 phillips from the left rear and 2 security T20 screws from the right side. I found that removing the 2 screws holding the bracket on the capacitor and the front allowed me to move the light housing enough to get to the bulb. In my case the bulb had unscrewed itself. I am not a big fan of the engineering associated with this model or the labor that assembled it.
Oct 23, 2010 | Electrolux Over-the-Range Microwave
Missing power supply
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Hisense TL1700 17 in. LCD Television
I'm trying to find a sweep board for s phillips 60' tv 1999 model
you have to get the actual part # from the board itself. Really the only way to get the part you'll need. Also make sure that it matches your tv model.
Apr 20, 2010 | Philips Magnavox 51MP392H Rear Projection...
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
May 17, 2009 | HP Computers & Internet
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Extreme White Glowing
Your CRT fluid needs to be replaced. Goto www.TvRepairKits.com and order their fluid kit.
Sep 28, 2007 | Philips 60PP9363 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
