Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
The latch on the hose (at the canister end) of my electrolux Guardian vacuum has broken. Do you know where I can buy this part. I found many places that are selling the entire hose, but all I need is the latch piece.
    Scholar:
  • 44 Answers
Find an Aerus dealer. You can go to aerusonline.com and use the dealer locater and find the closest store. Good Luck!!
Posted on Jan 02, 2009
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
How to remove electrolux guardian hepa filter
Open gadget compartment, remove all gadgets or attachments and the hepa filter will be below the vented frame...look next to the end with the hose and you'll see two spring clips (part of the vented frame) and squeeze them to allow the vented frame to release and move upward. This will expose the filter. Reinstall in reverse.
Mar 14, 2013 | Electrolux Guardian Bagged Canister Vacuum
How do i tell if I'm getting enough vacuum
Place you hand over the end of the hose and if the motor speeds up you are getting enough vacuum. The problem will be either in a full bag or something blocking the hose in the section on the floor (bit of paper--cloth etc.
Mar 09, 2013 | Electrolux Guardian Bagged Canister Vacuum
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
Where is the filter on an electrolux canister and how to you change it.
This model has the filter beneath the tools/attachments.
Open the hatch to gain access to the tools. Release latch/tab at the front of the tool holder, and lift. Remove and replace filter. This should be done every 6 bags.
For additional information, check your manual, or download one from the below link. The Guardian will be listed under "older models".
Dec 12, 2010 | Electrolux Guardian Bagged Canister Vacuum
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux canister C104A: Unit shuts itself off and LED in handle next to OFF button flashes.
I have a similiar problem, but LED light does not flash. I have determined it is a short in the hose wire. THERE ARE NO REPLACEMENT PARTS FOR THIS MODEL OF ELECTROLUX. I'll never buy another Electrolux product.
Oct 31, 2010 | Electrolux Guardian Bagged Canister Vacuum
Don't know where to turn on the vacuum of the electrolux guardian. Bought it used. Can you help?
Usually these types of vacuums havve a foot operated switch that is part of the body and kind of blends in with the body of the vacuum, they may also have a switch on the handle.
Feb 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
Canister starts, but vacuum does not start
Take the hose unpluged see vaccum is working or not.
IF NOT.
  1. BAG FULL
  2. HOSE CLOGGED
  3. BELT BROKEN/LOOSEN
Dec 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
56 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
