Question about Linksys Wireless-G WRT54G Router
Continuously lose connection
I have a desktop ethernet wired to the WRT54G and use a couple of laptops in the house via wireless. Quite often the internet connection is lost and if I unplug the ethernet connections and power to the router, and then reconnect, I regain connection. Connection may be good for a day or two or sometimes I lose connection several times within the same day. What causes this and is there a solution so I don't have to keep doing this?? I never have to touch the modem.
  • robinwalters Dec 16, 2008
    Thanks Joe. I certainly appreciate your advise and will give it a try. In the meantime your solutions indicate fixes for losing wireless connectivity, but I also loose connectivity through my desktop which is hardwired to the router. Advise?
  • rackda7878 Feb 05, 2009
    when i install the linksys router the link button light does not come on, and i dont have internet access at my lap top
  • Linksys Master
  • 4,338 Answers
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware.
For the Firmware update go to :www.linksys.com
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 15, 2008
  • JDTec
    JDTec Dec 16, 2008
    Then it can be that it needs a firmware update.
    Have you tried to reset it to default settings?
    Linksys reset
    The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL addresshttp://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
    Sniper:
  • 87 Answers
Try another wall plug power supply. These power supplies are low cost build and become very unreliable after some time of use. The Power Supply is rated at 5V but can not sustain that when connected to the Router.
I had exactly the same problem. Once I found a replacement power supply that worked, I opened the original power supply and found a capacitor blew and had cracked open.
It turned out the capacitor was under rated causing it to blow. I then just for the fun of it installed a better and properly rated capacitor, and tried this power supply again with the router. It still works today after about a year or so.
Anyway, hope this helps.
Posted on Feb 09, 2009
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Motorola SURFboard SB4200 With Buffalo Airstation
If it were me, i would return the airstation. then i would buy a linksys WRT54G. They are about 50 dollars. Then use that to set up your wireless network and you will find it quite easy.
Apr 24, 2008 | Arris SURFboard SB4200 Modem
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Apr 03, 2008 | Computers & Internet
Wireless
Are you doing this wirelessly or with a wire (Ethernet cable).?
Do the setup with an ethernet cable first, then try wireless after setting it up.
Oct 11, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
367 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
